Zetor 6245 fill plug
/ Zetor 6245 fill plug #1
Stratton6245
Zetor 6245
I have a zetor 6245 and the fill plug for the front diff is missing. Tried finding a bolt to fit it but a 10mm is too big and an 8mm is too small. If someone can help me out that would be great! Or have a part number for the actual plug so I can order one. This is the fill plug not the drain plug
/ Zetor 6245 fill plug #2
Maybe it's 9mm or 3/8" SAE. 😜
/ Zetor 6245 fill plug #3
it should be npt [ national pipe thread ], found at any hardware store pipe/plumbing.
/ Zetor 6245 fill plug #4
The bolt is a M8. This is the plug to check the oil level. It is to small to be a fill hole.
The fill hole is left on the axle. The drain hole is on the bottom of the differential.
The M8 bolt sits in a plate, if it is stripped out, this should be easy to upgrade to a M10.
Try Zetor-forum.de and use google translate, lots of good info about your Zetor.
2022 EZ-GO ELITE...
Cat 312 Excavator (A62679)
Cat 312 Excavator...
Golf Cart (pictures to come) (A62679)
Golf Cart...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2018 Ford F-150...
MIRRORS, MARKER LIGHTS, SWITCHES (A64276)
MIRRORS, MARKER...
2007 PETERBILT 386 (A65643)
2007 PETERBILT 386...
