Zetor 6245 clutch cylinder
   / Zetor 6245 clutch cylinder #1
mrblackwell
Wheel Horse 520-H
Hey guys, last week I bought a used 6245 with 300hrs, from a small town that was selling surplus equipment.
Before buying the tractor I knew the clutch cylinder was not working, however the clutch itself is fine. From what I've read, this is a fairly common problem with these tractors. There is some minor rust on the plunger in the slave cylinder, which I assume is from the slave cylinder leaking.
My questions are,
1- Should I replace the cylinder or try to bleed it ?
2-Where do you bleed it & where do you fill the reservoir ?
   / Zetor 6245 clutch cylinder #2
Great tractors. You'll like it. Yes, the master and slave cylinders on some old ones had that rust problem and also problems with the sealing rings internal. Given the sophistication of the rest of the tractor and the normal reliability of hydraulics it does seem odd that this happened to them. But I'd replace it and here's why: Zetor has always had a policy of constantly upgrading their basic design and making the new parts backwards compatible. That's darn near unique in manufacturing today, and worth taking advantage of. So if it was me I'd just get a set of new ones and make sure they are the latest type.
good luck, rScotty
   / Zetor 6245 clutch cylinder #3
If you need those new, I think I can take care of that? Ken Sweet
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A53472)
2012 UNVERFERTH...
2015 Eager Beaver 15HBB-PT T/A Flatbed Equipment Trailer (A50322)
2015 Eager Beaver...
2018 Forest River Grey Wolf 26RR Lmtd Toy Hauler (A52384)
2018 Forest River...
Guard Rail Pieces (A51692)
Guard Rail Pieces...
