Zetor 5245 fuel problems
/ Zetor 5245 fuel problems #1
solarsun
knowlton, quebec
zetor 5245
Can I view or download a Workshop manual or fuel system diagram for my 5245 anywhere? New member by the way!
/ Zetor 5245 fuel problems #2
Don't know, but if you describe what you're going through we can help you out. A fuel system isn't that hard to trouble shoot.
I had to pump the primer alot before it would start so I removed the fuel bowl and cleaned, changed the primer rubber seal and changed washers on the filter in the bowl, checked and tighten hoses and now I can't get any pressure on the primer so no fuel is getting into the bowl. When I take off the hose from the tank and lower it I'm getting fuel but not when it is level with the bowl connection. When I pump the primer I can see air bubbles in the bowl, I took it off and filled it with fuel to see if that would help, and also there is a burbing sound so I'm assuming there is a air leak somewhere. So I wanted to see where the inlet is connected to the tank which is difficult to see with the cab on. I have seen the new version of the primer pump, at approx. $75 I didn't want to spend that for nothing. Any help will be appreciated, one thing I've learned " IF IT AIN'T BROKE DON'T FIX IT "!
/ Zetor 5245 fuel problems #4
I think I understand what you've been though so far.
If it were me, I'd bypass everything up to the pump. (Fuel tank, lines, ect). Run a temp hose to the pump and into a container with a clean fuel, my favorite is a mason jar.
Try that and report back.
If there is a break (pre pump) there is a good chance it will leak air in (under suction) and not fuel out.
I did use a temp hose and started at the bowl and it turned out to be a bad gasket on the bowl, I ordered a new one and it fixed the problem. Pumped up nicely and started right up, thanks for the idea of the temp hose.
/ Zetor 5245 fuel problems #6
Glad you got it sorted out!
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2022 EZ-GO ELITE...
Stout Utility Grapple XHD84 (A66285)
Stout Utility...
17395SFL (A61568)
17395SFL (A61568)
2013 VOLVO A25F 6X6 OFF ROAD DUMP TRUCK (A62129)
2013 VOLVO A25F...
2023 CATERPILLAR 259D3 SKID STEER (A65053)
2023 CATERPILLAR...
