Zetor 5211 lift bouncing
   / Zetor 5211 lift bouncing #1
SPLnut
hitch bounces constantly when an implement is attached...
   / Zetor 5211 lift bouncing #2
Check the linkages from the position control lever and .....whatever it is called, the rod that communicates back to the valve where the rocker shaft's position is.
Low fluid check first, but I was assuming that you would have already done that before posting ?
   / Zetor 5211 lift bouncing #3
Does the tractor have draft control?
yes i believe it has draft control that's the 3rd lever
   / Zetor 5211 lift bouncing #5
Make sure the lever is all the way down and/or the top link is in the hole that isn't affected by draft control. Draft control senses downward force on the 3ph and could cause the symptoms you describe.
still bouncing...It'll go down 3 or so inches and bounce back up
   / Zetor 5211 lift bouncing #7
Your piston seals leak. Take off the 3pt lift cover with a workshop engine lifter (if it has a cab and you've removed the floor) and you'll see the big piston underneath.
The cylinder leaks oil and the position control keeps correcting that.
2014 Ford Flex SUV (A50324)
2014 Ford Flex SUV...
2014 PETERBILT 388 AUTO TRANSPORTER (A51222)
2014 PETERBILT 388...
Quick Attach Pallet Forks (A47384)
Quick Attach...
2014 Brent 1596T Dual Auger Grain Cart (A50657)
2014 Brent 1596T...
John Deere LX5 3 pt Rotary Mower (A50515)
John Deere LX5 3...
2020 Ford F-150 Crew Cab Pickup Truck (A50323)
2020 Ford F-150...
