Zetor 5211 lift bouncing
/ Zetor 5211 lift bouncing #1
SPLnut
hitch bounces constantly when an implement is attached...
/ Zetor 5211 lift bouncing #2
Check the linkages from the position control lever and .....whatever it is called, the rod that communicates back to the valve where the rocker shaft's position is.
Low fluid check first, but I was assuming that you would have already done that before posting ?
/ Zetor 5211 lift bouncing #3
Does the tractor have draft control?
yes i believe it has draft control that's the 3rd lever
/ Zetor 5211 lift bouncing #5
Make sure the lever is all the way down and/or the top link is in the hole that isn't affected by draft control. Draft control senses downward force on the 3ph and could cause the symptoms you describe.
still bouncing...It'll go down 3 or so inches and bounce back up
/ Zetor 5211 lift bouncing #7
Your piston seals leak. Take off the 3pt lift cover with a workshop engine lifter (if it has a cab and you've removed the floor) and you'll see the big piston underneath.
The cylinder leaks oil and the position control keeps correcting that.
2017 Xtreme Telescopic Telehandler (A60352)
2017 Xtreme...
2006 CHEVROLET 2500 SERVICE TRUCK (A63291)
2006 CHEVROLET...
New - Front mount rototiller
New - Front mount...
Lot of (Approx. 30) Venture Lighting 1,250W Metal Halide Bulbs - Fits Allmand Light Towers (A63689)
Lot of (Approx...
2019 CATERPILLAR CP54B PADFOOT ROLLER (A62129)
2019 CATERPILLAR...
2014 Ford F-550 Altec AT40M 40ft Material Handling Bucket Truck (A61568)
2014 Ford F-550...
