Zerts service manual 15 series
   / Zerts service manual 15 series #1
RPott
Waddell, AZ
Branson 3515H
Has anyone mapped out all of the zert locations for the 15's? Perhaps the service manual covers it. Know where I can buy one?
Thanks
   / Zerts service manual 15 series #2
The regular owners manual shows them for my 20 series. The only one that wasn't real clear is on the right side of the transmission case where the 3pt lever is attached. It's hard to see because of the rear tire. other than that it was all pretty clear. Did you check the maintenance section of the owners manual?
I'm not sure where to get a service manual for mine other than the dealer, but I will probably break down and do that in the future...
   / Zerts service manual 15 series #3
Lucky to be able to get one from Kukje.
I have as a comparison, a 2007 30 model manual and a 2016 00 model. The 16 is significantly better but both leave a lot to be desired.....clear, accurate, viewable photographs would really help work through the broken English. Kukje needs to spend quality time on their manuals like they do on their tractors. Also need a translator more fluent in the American version of the English language where one meaning could have half a dozen words describing it.
On zerks, my 2016 00 series only has zerks on the steering tie-rod ends at the front wheel gear boxes; very visible when viewed from the front. FEL is full of them but all are visible....same with the 30 series.
My 30 series has sealed tie rod ends. It has a zerk under the center of the front axle for that pivoting pin....allowing the front axle ends to move up and down as you go over uneven terrain. Then there are 2 which can be seen on the rear for automatic controlling of 3 pt lift and a shift lever as it goes into the central housing. That's it on the 30. Would assume your 15 would be about the same.
One thing I like are the drain screws.....painted yellow and the book is clear on them.
Thanks for the repsonse. You are right on about the limited help from the manual. I'm waiting on my dealer to get back to me about a service manual.
I apreciate you spelling out some locations for the 30 series. Helps me to look for those I'm sure I missed.
John Deere Disk Chisel (A50515)
John Deere Disk...
2007 Ford Expedition EL Limited 4x4 SUV (A50324)
2007 Ford...
Haulmaster Quick Hitch (A50515)
Haulmaster Quick...
2013 Peterbilt Heil Side Loader Garbage Truck (A50323)
2013 Peterbilt...
2014 Ram 1500 Crew Cab Pickup Truck (A50323)
2014 Ram 1500 Crew...
