Zert / Zerk Fitting issues
/ Zert / Zerk Fitting issues #1
Artisan
Veteran Member
Monrovia, California
Kubota BX25
I do not deal w/ this stuff daily, I hope a couple of you can steer me straight. I have a device w/ 6 Zert fittings in it and the OEM drilled the holes for the zert fittings to big and there falling out. The holes are drilled to .375 - .379" or so inches .
Is there a Zert bigger than this assumed 1/8" unit, if so what is that size, exactly what size drill bit should I use for what tap, please...
Who make sthe BEST zert fittings?
I just do not deal w/ this stuff enough to know.
TIA!
/ Zert / Zerk Fitting issues #2
Zerk fittings come in a variety of thread sizes. Some are pipe threads and some are bolt threads.
In your case you might go to the local tractor supply or auto parts store and find ones with the next larger size thread. Then you could drill and tap the hole to that thread size and be all set.
/ Zert / Zerk Fitting issues #3
might check for metric sizes of grease zerts. try a bolt and screw supply house.
Well, ummmmm, errrr yes, but, and, but-some-however, except I was gonna and the sun is still in my eyes ...... :laughing:
I am trying to be exacting w/o going the "try this and try that" route, although I may have to do it.
I remeasured and all holes average .383" in diameter. I can drill bigger if needed.
Time passes I keep looking...........
BINGO ( I hope...)
So I found a 1/4-18 NPT thread angled Zerk at grainger and I have a 14-18 tap so if I drill w/ a 7/16" drill bit (.4375) I think I will live.
( I STILL WISH I HAD A LIST OF ALL SIZES AND FLAVORS OR ZERKs NEEDED FOR A BX25 ! )
/ Zert / Zerk Fitting issues #6
With your ability to measure the size of the holes to 3 decimal places you have a good understanding of tolerences. If the fitting ae falling out they might be a non -threaded drive fit type. This style is not the best as a tight grease gun can pull they out. I have never had a proper threaded grease fitting pull out, the worst case has been in that the hose end had to be yanked off.
Craig Clayton
Craig indeed I learned this morning while reserarching that there are pressed in type zerks. Existing is what I believe to be a 1/4-28 "tapered" zerk and the holes are all drilled straight through.
I am seting up to drill to 7/16" and use a 1/4-18 NPT tap for the Zerks I found at Grainger, "hopeing" I am making the right decision :cool:
/ Zert / Zerk Fitting issues #8
Yes Steve, I saw that too and I nixed the idea and am going with good old fashion proven NPT threads, it helps I am a little bit familar w/ them from my job. :D
/ Zert / Zerk Fitting issues #10
Maybe I'm not following correctly. Drilling 7/16" hole for a 1/4" zerk? I suggest pulling one out, going to the parts store and buying the next size larger. Some are even self tapping. If you find the size and thread of tap you need, google it and find out what drill bit you need. Just remember some zerks are pipe threaded so a straight hole isn't going to work out well.
/ Zert / Zerk Fitting issues #11
Artisan, a 1/8-27 NPT thread takes a .339 tap drill (letter drill R) also it possibly could be metric, a M10x1.5 thread takes a 8.5mm (.334) tap drill. I'm assuming you measured the ID of the existing loose threads. Id probably use the 1/4-28 NPT also should be big enough to clean up the old hole and give you a true hole to re-tap. Also since you already have the tap thats a plus too
Yep, I found 1/4-18 NPT Zerks....should screw right in and work for my lifetime...
TU Wireman...I might have done that 45 minutes ago! HA! I found the NPT tapered Zerks and I just finished tapping all 6 holes to 1/4-18 NPT Grainger will deliver Monday - Tuesday and I will post up pics of what I am doing. My new log splitter is a beauty...:thumbsup:
/ Zert / Zerk Fitting issues #14
What's the best way to keep drill and tap cuttings from getting inside the joint to be greased?
/ Zert / Zerk Fitting issues #15
Put a heavy grease on the drill and tap flutes, remove and clean as needed. Chips will stick in the grease and come out when you back out the tap.
/ Zert / Zerk Fitting issues #16
Sorry to highjack this thread, but it is on topic. Stupid question here from a novice. I started my first 10 hr greasing this weekend and found that the grease gun is very difficult to pull back off the fittings. Is this normal? Is there a trick? Goes on easy enough, pumps the grease in very well, but is hard to pull back off. Kubota grease gun on a Kubota tractor. There's no mechanism like a QD or anything on this gun fitting that I can tell. I'm afraid I'll damage the fittings on the tractor if I keep yanking on it to get it back off. TIA. :)
HA! Silly grease guns! here, I will save you all the reading...
THE HEAD IS ADJUSTABLE, UNSCREW IT TO LOOSEN IT's GRASP, and go buy a Lincoln electric or pneumatic grease gun. James' 2nd link above is to the 10 page thread on grease guns I started. It should be mandatory reading for all new tractor owners. :laughing:
And what kind of gun is it? Post up a picture of the tip too!
/ Zert / Zerk Fitting issues #20
Wow; thanks guys. Great links. I understand. Felt stupid being a former aircraft mechanic and pretty solid DIYer that I didn't know more about grease guns. Glad I asked though.
2017 Ford Explorer AWD SUV (A66738)
2017 Ford Explorer...
2011 MAGNUM TRAILER LIGHT PLANT (A67714)
2011 MAGNUM...
ROOM WITH MISC ITEMS (A68842)
ROOM WITH MISC...
2009 FORD E350 CARGO VAN (A66091)
2009 FORD E350...
John Deere 6420 (A64911)
John Deere 6420...
PORTA POTTY (A68842)
