zerox copier not workin, ideas?
/ zerox copier not workin, ideas? #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
got a zerox xc1040 copier that just stopped putting print on copies.
It's an older unit.. say from 98 or so.. but been a good copier.
we repalce the drum when signaled, same as the tonor.
I've had to change the fuser lamp once, and the corona wire ( they call it a cortron wire ) module once as well.
While I'm not a copy repair man.. electronics is not new to me.. and I've done a good bit of copy repair ( parts replacement ) on toshiba unit as well as basic disassembly and cleaning on zerox units.. replacing modules..e tc.
when you cope if you set to darkest intensity, you may get a ghost image on the paper the last 2 ".. but nuttin else.
lamp at the top glass is coming on and transport works and moves up and back. paper feed seems fine.. tonor cartridge is new within a few weeks, and drum indicastor is not on.
ideas?
thanks
soundguy
/ zerox copier not workin, ideas? #2
the rubber roller mite be shot.
eh.. can you be a lil less vauge?
( paper feed mechanism is working fine.. paper picks up, goes thru mechanism right past tonor and drum, and out thrui the fuser, nice and warm and bright white )
looking at the tonor cartridge, it is still full and the lil roller that picks up the tonor keeps a nice fuzzy full covering, as it is spun. and drum is realitively new.. say.. month old..
soundguy
Deere 700K (A64126)
Deere 700K (A64126)
2023 VOLVO ECR25 ELECTRIC EXCAVATOR (A60429)
2023 VOLVO ECR25...
Case IH 315 Magnum (A62177)
Case IH 315 Magnum...
Parker 500 Auger Wagon (A66285)
Parker 500 Auger...
2006 GMC Savana 3500 Box Truck (A61573)
2006 GMC Savana...
2018 INTERNATIONAL LT625 DAY CAB W/ WETLINE (A62613)
2018 INTERNATIONAL...
