Zeroing in on LS or Kioti but I have some ?
   / Zeroing in on LS or Kioti but I have some ? #11
DK-40 all the time. Tier 3 if possible, cheaper to buy and avoids Tier 4 unknown as yet possible issues. Huge lift capacity, and there isn't really an LS comparison 1 for one. That's what the mfgs do; make it impossible to compare apples to apples. Once the Tier 3 DK-40s are gone that's it. If you've got the 2K it is well spent on the DK.
   / Zeroing in on LS or Kioti but I have some ? #12
I own a CK30 HST and wish I had bigger. Go with the DK or down the road you'll wish you went bigger, especially for only a couple K.
Kevin
   / Zeroing in on LS or Kioti but I have some ? #13
I was eyeing the CK 30 last year, waited a few months, and then zeroed in on the DK. No regrets...
   / Zeroing in on LS or Kioti but I have some ? #14
I have a DK35se.. They don't make it any more.. Just 4 inches shorter frame, and missing one cylinder (3 instead of 4) that the DK40 has. But these are extremely nice full featured tractors with lots of capability.. If I had round bales to move, I would get the DK40se, and not look back. You need the lift ability and frame size. You will not be disappointed.
   / Zeroing in on LS or Kioti but I have some ? #15
If you can find one, an LS R4041 is very similar to a DK40SE. If not, the newer (Tier IV) XR4040H is also very close.
I compared the 4041H to a DK40SE (dealer carries both brands), and they both have pluses and minuses. The biggest two advantages (in my opinion) for the DK are loader lift height, and the rear 3pt control lever. For the LS, I found I could go up to the 4047, and get a decent increase in power, have larger wheels and tires, and spend a bit less. I also liked the layout of some of the controls better on the LS, but it wasn't enough to sway me either way.
This was at least 1200lbs of concrete culvert, and the loader played with them...I don't think I raised them to full height, but close enough that I know it would have done so easily. Large round bales wouldn't be a problem.
   / Zeroing in on LS or Kioti but I have some ? #16
Get your machine with loaded AG tires whatever brand you pick.
   / Zeroing in on LS or Kioti but I have some ? #17
Or get it with loaded Industrials, like mine.;)
   / Zeroing in on LS or Kioti but I have some ? #18
I had a CK30 and traded it in for a DK40. I needed the power of the DK, but after a year of owning the DK, I miss the maneuverability of the CK. I prefer the single HST pedal of the CK to the dual pedals of the DK. I find the CK did less damage to the lawn and I find I am having to use 4wd more often in the DK than I did with the CK. There are a few features of the DK that I like better, mostly convenience features. If the CK FEL will lift what you need and will run the bushhog you want... then get the CK. If you need the lifting power of the DK FEL and the PTO power of the DK to drive the bushhog, then go with the DK.
   / Zeroing in on LS or Kioti but I have some ? #19
I posted this on other threads but since you are in Upstate NY a local dealer has these units in stock.
The R3039H would also suit your needs. XR's are the new tier 4 tractors. DK series are good tractors also. Whatever fits your needs and feels good in the seat. All of us here will be more than willing to help spend your money. Lower price means you may have extra to spend on attachments.
Local dealer here has the following prices posted online. Use them as a guideline. You can check all the features and specs of each on the LStractor site.
G3033 $14,999
G3033H $15,999
G3033TLB $20,999
R3039 $18,999
R3039H $19,999
XR4040HC $26,999
XR4040TLB $28,999
At this time he has no XR3032 or XR3037 left in stock
   / Zeroing in on LS or Kioti but I have some ? #20
Welcome to the same series of decisions many of us got ourselves into when new tractor shopping. I do subscribe to the theory that you'll never be disappointed with more tractor than you think you need but whatever savings you gained by doing anything less won't provide much comfort when it fails to do what you ask.
I originally began my search thinking the CK35 would be plenty of tractor for my needs - and it very well could have been. All I know is I have no regrets making the $2k jump to DK.
WE DO NOT GUARENTEE HOURS UNLESS WE SAY SO!!! (A50774)
WE DO NOT...
Gravelly Pro-Turn 148 48in Zero Turn Mower (A48082)
Gravelly Pro-Turn...
2017 Nissan Maxima Sedan (A50324)
2017 Nissan Maxima...
1263 (A50490)
1263 (A50490)
AGT Agrotk 680 Drop Hammer Attachment (A47384)
AGT Agrotk 680...
2015 JOHN DEERE 5100M TRACTOR (A51243)
2015 JOHN DEERE...
