Zero Turns at Home Depot??
   / Zero Turns at Home Depot?? #2
I don't think I can help you too much but seeing as I just went through researching and eventually buying a new lawn mower, I'll through in my 2 cents.
I wanted a ZTR also - due to landscaping, trees, and general stuff on my 2 acres. The residential equipment at the box stores is entry level stuff and similar in quality (integrated pump and wheel motor rather than separate motors and pumps). I'd decided on either JD or CC initially. I noticed a few returns with seriously slashed tags but full warranty at HD. I thought I'd probably go that route hoping to get a deal and started going to check them out every day to see what came back. I asked the manager which brands come back most often for warranty or return - Toro, CC, then JD least. I did the same at Lowes - Troybilt, Husqvarna, then JD least.
I ended up getting none of those. I bought a JD X324 with 4-wheel steer. The uncut radius is 9" - its not ZTR but close enough for me. Cost a bit more than the entry level machines but it also has a 4-yr warranty.
   / Zero Turns at Home Depot?? #3
I would recommend the JD....because I have one! LOL! But I have the Z425 and like it, which does have the separate pump/motors. But all seriousness aside, I think the integrated pump/motor units are fine for non-commercial use. That's what's offered on the $4K+ Bad Boy ZTR's with fabricated steel decks. And where will you take the other two when you need service/repair? There's always a John Deere dealer nearby (usually, in most areas of the country). And they sell that same Z225 model off their showroom floor.
   / Zero Turns at Home Depot?? #4
JD if you MUST go to the box store to use the gift cards. The thing about them is after you buy it they could care less. If you buy the same thing from a good dealer he will take care of whatever comes up. If I was a dealer and you brought a box store mower to me for warranty, I would do it, but you would be at the end of the line waiting a while.
   / Zero Turns at Home Depot?? #5
larso1 said:
...I think the integrated pump/motor units are fine for non-commercial use. That's what's offered on the $4K+ Bad Boy ZTR's with fabricated steel decks.
Yep. Tractor Supply sells the Bad Boy ZT for $5k. I think all the residential versions of the ZTR's have the integrated pump/motor units.
   / Zero Turns at Home Depot?? #6
sucks to get those cards and be stuck buying at a certain store, I have run into that myself. If you are going to get a mower with them, then as much of a JD man as I am I think the Toro z5000 is the best of the bunch in this crowd. I know several guys that mow grass for a living that use this mower and they all really like it. dollar for dollar it stands near exmark as far as quality and reliability goes.
   / Zero Turns at Home Depot?? #7
I went to the local Toro dealer because I like Toro brand equipment and they are having 0% for 36 months on some of their mowers. While there, the dealer showed me a Country Clipper mower that had allot of features I liked. Easy access to everything, all metal and heavy duty. No sealed bearings either. What I'm not excited about is the B&S engine and the single hydraulic pump. It has joystick control for stearing, which might be good or not, I'm not sure on that. They also offer handles to stear with like the other mowers.
I'm going to check out Kubota and Deere this week sometime and one other lawnmower shop that I like. Their main brand is Scag, but I know they have other brands too.
The mowers that I saw at Home Depot and Lowes were all kind of light weight compared to what I've seen at the dealers. I don't need commercial, but I want something heavy duty that will last. The Deere Zero Turn at Lowes that I looked at yesterday had a hydraulic leak and it was brand new, just sitting there.
Eddie
   / Zero Turns at Home Depot?? #8
gdbauer7 said:
I have a couple HD gift cards I am going to use on a ZTR mower, of the ones available at HD for under $3000 which is the best option? Mowing one acre thats flat with a few trees and fence to mow around. thanks
$2000 - 3000 - Zero Turn Mowers - Riding Mowers - Mowers & Utility Products - Outdoor Power Equipment - Outdoors at The Home Depot
I have owned 3 ZTR,s.Trust me on this one,BUY FROM A LOCAL DEALER WHO GIVES YOU GOOD SERVICE AFTER THE SALE!Not from a box store that could not care a red rats behind after they sell you a mower.coobie
Pitts Tri-Axle RGN Lowboy Equipment Trailer (A50322)
Pitts Tri-Axle RGN...
2012 Chevrolet Silverado 2500HD Enclosed Service Truck (A52377)
2012 Chevrolet...
Echo SRM2620 Gas Trimmer (A52377)
Echo SRM2620 Gas...
2017 Mitsubishi Outlander Sport SUV (A53424)
2017 Mitsubishi...
2020 FREIGHTLINER M2 SINGLE AXLE BOX TRUCK (A54607)
2020 FREIGHTLINER...
