Zero turn won't start after it's been running
   / Zero turn won't start after it's been running #1
Mjulson
Austin, TX
Husq RZ 5424
Hi there, new here and hoping someone can help me out.
I have a problem with a Husqavarna RZ 5424 with a Kawa 24 HP motor.
It began with after mowing for a while, I'd stop for a drink, come back starter won't spin. Leave it for a while and starts right up.
Checked all connections, fuse, tested battery was fine, couldn't find anything.
This happened maybe 4 times(different days), so it was pretty consistent.
Next time it happened, I was tired of waiting or towing it to the garage, so I grabbed jumper cables and connected it to my jeep and bam, started right up! Excited, I run down and got a battery, even splurged and bought one with an extra 150 CCA! Swapped it out, everything ran great, but only that evening.(yesterday)
Today, my son tries to cut the lawn, gets halfway done, stops, it won't restart. Ugh! Grab the jumper cables, hook them up, makes no difference. I then disconnect jumper cables from Jeep, and decide to by pass solenoid. Starter spins and engine starts right up!
So, I don't think it's safety switches like seats, blades, etc..
The only things that make sense is solenoid and wire harness. I read on a different site, about a different mower/motor, someone commented the valves might need adjustment because they could be open causing the compression to be too high, but I don't know what to make of that.
Any ideas what to do next? I think I'm going to order the solenoid. It's $15 on amazon and looks like a 5 min change. But this is really frustrating.
   / Zero turn won't start after it's been running #2
The same thing happened to my zero turn awhile back. I'd mow for a while, go in and grab some lunch, then it wouldn't start. Then it would start right up a few hours later. It turns out it was bad gas. The gas had water in it. The repair shop had to drain all the gas, replace a few things. None of it covered by warranty. I only get my gas from one place now.
I don't think it's gas. Would your starter spin at all? My starter doesn't spin. If it was bad gas, I would expect it to spin, but never fire up or stay running. I think it's gotta be electrical, since I can get it to start by bypassing solenoid.
   / Zero turn won't start after it's been running #4
Check your grounds and connections good first. Where the ground wire is bolted to frame take it loose and make sure it's clean / shiny.
Will do. Any thoughts why it would only be intermittent when it's been running and hot? And when I jump solenoid, I'm only jumping hot, so ground would be the same.
   / Zero turn won't start after it's been running #6
Mine did that twice. Once it was the ground connected from the battery to the motor/frame - the motor/frame side was loose and the next time the little hole in the gas cap got obstructed and it would not start after it had run a while.
   / Zero turn won't start after it's been running #7
really hard to do much troubleshooting if you dont have a volt meter.
IF you do have one and know how to use it, you can start tracing the circuit from the switch to the solenoid and see where you are loosing power.
It is very possible you have a bad or loose connection somewhere. And just getting on, sitting down, and jarring things around may explain the intermittent part
   / Zero turn won't start after it's been running #8
is this the ohv model if is adjust valves my mower did same thing found out very common problem valves get tight when engine gets hot can turn motor past compression and it would start
   / Zero turn won't start after it's been running #9
When mine wouldn't start. The starter did try to turn the engine. I didn't key in on that symptom you described. I didn't do much troubling shooting after. I just sent it to the dealer and they blamed it on the gas.
   / Zero turn won't start after it's been running #10
I'm having the same issue with my Bad Boy with Kawasaki engine. Like you, I thought it was the battery. Replaced it and it did fine for a mowing then started doing it again. Mine will click, but not kick in the starter. Jumping it helped. Turning the key 12-15 times and it will finally kick starter in...sometimes. I'm thinking a relay or some such now, but I dunno. Maybe someone will be able to help the both of us.
SKID STEER FORKS (A53843)
SKID STEER FORKS...
2022 New Holland Workmaster 120 MFWD Compact Utility Tractor (A55302)
2022 New Holland...
2012 Chevrolet Silverado 2500HD Enclosed Service Truck (A55788)
2012 Chevrolet...
2007 Ford F-150 4x4 Ext. Cab Pickup Truck (A53422)
2007 Ford F-150...
2014 BMW 328i Sedan (A53424)
2014 BMW 328i...
2018 MACK PINNACLE (A53843)
2018 MACK PINNACLE...
