Zero turn mower question
   / Zero turn mower question #1
James Runchey
The guy who is currently mowing my yard has a Hustler Raptor that looks very impressive. I was considering getting one and then I read somewhere that it wouldn,t hold up pulling much weight in a lawn trailer. Any truth to this? i have a bunch of dirt to move and wouldn't want to wreck a new mower. Maybe I should just stick with plan one, an x360. Any thoughts?
   / Zero turn mower question #2
A zero turn is for mowing, a tractor is for hauling.
   / Zero turn mower question #3
This is true.
Commercial grade ZTRs can handle pulling a bit more weight, but they are no Garden Tractor on that front.
   / Zero turn mower question #5
Zero turn mowers have the power but not the traction. We have Grasshopper with high traction tires. Before we got our tractor we used to pull 4' by 8' trailer usually loaded with wood (at least 1000 lb). It could pull quite a weight on flat but it lost traction on slopes. You will not wreck the mower but your turf by slipping tires. My wife still pulls garden trailer with her gardening stuff.
   / Zero turn mower question #6
I think you'd need some weight up front too. Although I haven't done it (yet), it's not too difficult to pull a wheelie with a ZTR.
   / Zero turn mower question #7
The hydro drives on most zero turns are not made for pulling hard. They are setup for fast movement needed for mowing.
Generally speaking zero turns should not be used to pull heavy trailers or rollers.
2016 FORD INTERCEPTOR (A51406)
2016 FORD...
2004 Range Rover HSE SUV (A51694)
2004 Range Rover...
Polaris Side by Side (A50324)
Polaris Side by...
2018 Taylor-Dunn BigFoot B5-440-36 Electric Utility Cart (A50324)
2018 Taylor-Dunn...
2016 Ford F-550 4x4 12FT Landscape Dump Truck (A51692)
2016 Ford F-550...
2006 Reelmaster Toro 3100D Mower (A50324)
2006 Reelmaster...
