Coyote machine
Super Member
- Joined
- May 4, 2009
- Messages
- 7,641
- Location
- Southern VT
- Tractor
- 22 SANY SY 50U, '10 Kioti DK 40se/hst KL-401 FEL, loaded tires, KB-2485 bhoe, Tuffline TB160 BB, Woods QA forks, MIE Hydraulic bhoe thumb & ripper tooth, Igland 4001 winch, & GR-20 Log Grapple. Woods BBX72" Brush Mower. Diamondplate aluminum canopy
My relatively new tractor, 150+ hours seems to have some zerk fittings that refuse to take on grease. When the nozzle is applied the grease squirts out between the zerk and the nozzle and does not go into the fitting. Have tried several different grease guns, lever and pistol grip handles, and one hand holding the nozzle on the zerk and any other way I can think of. In one case I unscrewed the zerk and attached the gun hose directly to the port and had some better success, but when I removed the gun's hose from the hole the pressure in the fitting wanted to return the grease to my shop floor.
Am I missing something?
I know TSC has a fitting that is designed to blow out zerks that don't work or joints that are filled with hardened grease with a penetrating oil or something similar- would this be advised?Grease Joint Rejuvenator - 3950995 | Tractor Supply Company
Any comments, suggestions, solutions would be appreciated.
