Loader Zerks for 100hp TYM/Mahindra Loader
   / Zerks for 100hp TYM/Mahindra Loader #1
4Papa
Central MA
TYM T1003
I have a 2015 T1003 TYM and I'm posting here as well as it's the identical machine to Mahindra's model of the same year. Anyway, does anyone happen to know the size of the zerks for the loader? Due to their recessed location in the loader arms, I snapped off a few nipples attempting to remove the grease gun nozzle while greasing this past weekend. I figured the stock fittings were a standard size but that doesn't appear the case. The stock zerks fit a 10mm socket but replacement 10mm fittings that I purchased both locally and via Amazon are too big for the socket. My selling dealer has no clue. This model loader also was used on the 90hp version. Thanks.
   / Zerks for 100hp TYM/Mahindra Loader #2
Taxutor Metric Hydraulic Grease Fittings SAE Standard 120-Piece Kit - Straight, 90 Degree, 45 Degree Angled Grease Zerks Fitting Assortment Set https://www.amazon.com/dp/B07M7T92K5/ref=cm_sw_r_cp_api_i_WPNaDbF51MVE8
Drive Grease Fitting Kit - 100 Piece Assortment https://www.amazon.com/dp/B00KKSGF1K/ref=cm_sw_r_cp_api_i_-TNaDb3H79EYT
The could be any thread type. Buy an assortment. They could also be a press fit type- called “drive type”. Those look like the link below and the more expensive link above. Once you get the press in type out you can chase some threads and screw in a fitting if you want.
Lumax LX-3505-10 Gold/Silver Drive Type Straight 0.50" Long Grease Fitting for 3/16" Diameter Hole, (Pack of 10) https://www.amazon.com/dp/B0059HKUFY/ref=cm_sw_r_cp_api_i_BUNaDbZ9CZSZ2
I'll check them out. Thanks.
   / Zerks for 100hp TYM/Mahindra Loader #4
A 6mm zerk will probably have a 10mm hex for the socket and a 10mm zerk will have a 12/13mm hex. Just like a 1/2" bolt has a bigger 3/4" hex.
   / Zerks for 100hp TYM/Mahindra Loader #5
My dealer finally got some from Mahindra but it wasn't easy, Mahindra wanted him to buy the pin it fits into along with the zerks. I was just over there looking for more since I'm down to a few extra for our tractor (4540) and the backhoe.
Is the sizing of the zerk (ie. "6mm") the diameter of the threads or the size of the orifice through which the grease passes?
My not-so-local dealer found some zerks at $4.99 each. I told him to hold off as I found some 1/8" NPT zerks that appear to work just fine, if a little longer. The threads appear consistent with the stock zerks.
   / Zerks for 100hp TYM/Mahindra Loader #8
Thread size......just like bolts.
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
DOOSAN G25KW GENERATOR (A58214)
DOOSAN G25KW...
2016 FORD F550 CREW CAB SERVICE TRUCK (A59905)
2016 FORD F550...
16ft T/A Utility Trailer (A59231)
16ft T/A Utility...
2018 HYUNDAI VC2530152-JS DRY VAN TRAILER (A59575)
2018 HYUNDAI...
TANK MANIFOLD (A58214)
