ZERK CLEANER???
   / ZERK CLEANER??? #1
Williy
Elite Member
Texas
Yanmar YT 235C Yannar YRC 60 rotary cutter, Yanmar RT72 rotary tiller B75 Backhoe & bucket & thumb, LS land grader
This is a tool to clean out your zerks
willy
   / ZERK CLEANER??? #3
I have one, but never used it. Back when I was working I could have used one, sometimes when my Crane was in the shop
and I had a spare out, there was a couple of zerks that the lazy operators wouldn't grease.
What I've learned from this forum is to stay away from the clay based grease. I use moly grease and grease when the
zerk require it.
   / ZERK CLEANER??? #4
I've had one in my shop for many years, used it a few times. It always cleared the clogged zerk fitting. It works.
   / ZERK CLEANER??? #5
16 minutes of video to show us that the tool doesn't work. That fact alone is enough to get me to question the guys intelligence.
I find that often if you take the weight off of the joint, ie. in this case lift the tires off of the ground. That's enough to let grease into the fitting
If he would have thought his way through the problem, there's a real good chance that the tool would have worked.
   / ZERK CLEANER??? #6
Just a thought but maybe you could apply heat and soften up the clog before using the tool?
IDK for sure, but me thinks that might help.
   / ZERK CLEANER??? #7
Have one as well, but I made my own in the shop. I rarely use mine simply because I only grease with non clay based grease which never hardens in a fitting and is easier to clean up as well.
If I have a questionable fitting, I just replace it with a new one. Have plenty of SAE as well as Metric fittings on hand.
   / ZERK CLEANER??? #8
Agreed. I make it a point to locate and service all zerks on all of my equipment regularly.
A habit I developed while operating for a grading contractor who insisted I start the tractor and get off and grease every fitting every day before starting work. Admittedly a little excessive but his belief that grease was a lot cheaper than repairs is true. And it gave the machine a few minutes to warm up before operation.
2025 ZWB 59in Excavator Boom Mini Skid Steer Attachment (A53421)
2025 ZWB 59in...
2014 CATERPILLAR CT6605 SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
New Holland C185 (A47477)
New Holland C185...
Crosley 10ft Hydraulic T/A Dump Trailer (A50323)
Crosley 10ft...
2017 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A52377)
2017 Chevrolet...
KUBOTA M7-132 LOT NUMBER 31 (A53084)
KUBOTA M7-132 LOT...
