ZD326P-60 Blade sharpening
   / ZD326P-60 Blade sharpening #11
is there a chance in **** one of you guys can scan the pages on deck leveling for a 326p and post them? my deck looks and measures level but on a slope the discharge side is cutting way to low. i have done everything in the world i can think of to remedy the problem. on a flat piece of ground the cut is perfect but if i run a sideways on a slope the discharge is way lower. the cut looks horrible and im to the point of taking it to the dealer but i dont know how they are going to reproduce the problem.
--- blades 2 sets a year, makita cordless impact, i have the lift but just drive in to front bucket of my b3030 raise it up and get after it. rotate blades every time, sharpen every 10-15 hours and wish they were made of something much harder.
   / ZD326P-60 Blade sharpening #12
I will scan the pages here in a bit and post them. I know the leveling process is a PITA. Took me way longer than it should have and I thought is was just me.
   / ZD326P-60 Blade sharpening #13
   / ZD326P-60 Blade sharpening #14
Thank you 1savoy!!!
Good looking cut today still a little jacked on slopes but some non recomended scalper adjustment had made a world of difference with the accurately adjusted blades now
   / ZD326P-60 Blade sharpening #15
Hey, That's great. Glad the cut is looking better. I sometimes think I get a cut that is slightly off on slopes, not that I have much where I am at. I have wondered if it is just the weight of the mower deck shifting when on the slopes?
   / ZD326P-60 Blade sharpening #16
Have you adjusted your guide wheels properly?
2008 Ford E-250 Cargo Van (A50323)
2008 Ford E-250...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A51039)
2006 Magnolia Dry...
AC CHARGING MACHINE (A50854)
AC CHARGING...
2019 CATERPILLAR 308 CR EXCAVATOR (A51242)
2019 CATERPILLAR...
2007 PETERBILT PB335 LUBE TRUCK (A51243)
2007 PETERBILT...
2016 PETERBILT 579 TANDEM AXLE SLEEPER (A51219)
2016 PETERBILT 579...
