ZD326- How to lube the deck height knob
   / ZD326- How to lube the deck height knob #1
Charlie MacGregor
After six years it's getting sticky. I've peered under and around the shroud but didn't see an obvious access to the shaft. Hoping I don't have to remove the shroud. Anybody done this?
Thanks,
Edit. Does the shop manual cover things like this and is it worth the $60?
Thanks
   / ZD326- How to lube the deck height knob #2
Also interested.
   / ZD326- How to lube the deck height knob #4
On my L3400hst the drop knob/shaft was frozen when the tractor was delivered. I used some Kroil to bust it loose, and some Fluid Film once in a while to keep it lubed up. Don't crank too hard on that shaft as it is small and somewhat delicate.
   / ZD326- How to lube the deck height knob #5
I'm wondering that a real lube job might affect it ability to stay on its setting when in motion.......just wondering.
8" & 10" I BEAMS & 6" & 8" CHANNEL IRON UP TO 25' (A51247)
8" & 10" I BEAMS &...
2018 John Deere R4038 Sprayer (A53342)
2018 John Deere...
ECHO PE-225 GAS WEED EATER (A51248)
ECHO PE-225 GAS...
FORD 8770 TRACTOR (A51247)
FORD 8770 TRACTOR...
Polaris Side by Side (A50324)
Polaris Side by...
FRONTIER WR3210 LOT IDENTIFIER 108 (A53084)
FRONTIER WR3210...
