ZD326- How to lube the deck height knob
   / ZD326- How to lube the deck height knob #1
Charlie MacGregor
After six years it's getting sticky. I've peered under and around the shroud but didn't see an obvious access to the shaft. Hoping I don't have to remove the shroud. Anybody done this?
Thanks,
Edit. Does the shop manual cover things like this and is it worth the $60?
   / ZD326- How to lube the deck height knob #2
Also interested.
   / ZD326- How to lube the deck height knob #4
On my L3400hst the drop knob/shaft was frozen when the tractor was delivered. I used some Kroil to bust it loose, and some Fluid Film once in a while to keep it lubed up. Don't crank too hard on that shaft as it is small and somewhat delicate.
   / ZD326- How to lube the deck height knob #5
I'm wondering that a real lube job might affect it ability to stay on its setting when in motion.......just wondering.
Komatsu WA250-5L Wheel Loader (A52384)
Komatsu WA250-5L...
(1) 275 Gallons of Aluminum Brightener (A51573)
(1) 275 Gallons of...
(APPROX 34) 1 1/2" X 10" X 38" CHANNEL IRON (A51247)
(APPROX 34) 1 1/2"...
2008 DOOSAN G25 GENERATOR (A52472)
2008 DOOSAN G25...
