ZD326 blade stops turning when in high grass
   / ZD326 blade stops turning when in high grass #11
Sounds like the 2 coned spring washers have flattened out
OR
you don’t have the components assembled correctly.
Now that my blades are on tight, I have a new problem. I started to cut grass yesterday and the same blade was loose again. I had only cut for about 5 minutes. I drove it to my shop to work on it, turned the key off and it kept running. I looked for wires to pull to kill it and couldn't find any that killed it. I took the key switch off and unplugged it but it kept on running. I sat back and tried to think of a solution to kill it. After about 5 minutes, it started missing out and sounded like it was running out of fuel although the tank was almost full. Then it killed.
I waited a few minutes then hit the starter and it started right up. I turned off the key and it killed and has worked fine since. Anyone know what could have made it refuse to kill?
   / ZD326 blade stops turning when in high grass #13
98ft lbs on those small 10mm threads sure seems excessive :oops:
Is ZD326/331 the same setup as ZD1211 in the pic illustration in post #5 ?
   / ZD326 blade stops turning when in high grass #14
If you havent yet, try new bolts. Those may be too stretched.
   / ZD326 blade stops turning when in high grass #15
what a dumb design, the blades aren't keyed?, I would torque the cup washer to blade at the proper torque, then I would weld the cup washer to the blade itself. Ridiculous design.
Basically all zero turns along with virtually all other riding mowers use round hole blades. I don’t know what bases for comparison you’re using to say it’s a terrible design. I would venture to say the Kubota zero turn is the strongest design on the market. Kubota has a shaft drive deck. Basically all the others use a drive belt that slips under high load. The Kubota uses a double belt to drive the blades that’s last upwards of 1k hours. Virtually all the others use a single belt that only last a few hundred hours. The Kubota blades use a splined washer on the blade that’s better than just a regular bolt that virtually all the other zero turns use.
   / ZD326 blade stops turning when in high grass #16
The illustration in post 5 says 98-117 newton meters. If I translated right the top end of that chart at 117 is 86 foot pounds.
   / ZD326 blade stops turning when in high grass #17
Assuming the op has the bellview washers oriented correctly, I would be inclined to torque the bolts a little more. Perhaps add a 3rd washer and increase the bolt torque if there is enough thread (I've never added a 3rd washer).
I don't use a torque wrench on the blade bolts for my zd326 or zd1211, but I'm sure I keep them tighter than 98 ft/lbs.
I take the blades off to sharpen every 2 weeks or so, and have never had a problem with them.
You’re way over doing it with in excess of 100 ft pounds on a 10mm bolt. The blade bolts are self tightening anyway. I only put mine on snug and they never slip.
   / ZD326 blade stops turning when in high grass #18
virtually all? I have personally seen it once, I have worked on maybe 50 different riders over my years, and all of the ones I worked on had a star variant stamped blade which is what kept it in place on the on the spindle from slipping, that said I have not worked on more industrial machines, usually lower end consumer grade stuff.
I have multiple machines on a single belt at close to 1k hour with no wear, so not sure I agree there at all
   / ZD326 blade stops turning when in high grass #19
Never had a round hole blade that didnt also have pin holes. My ZT uses pin holes.
   / ZD326 blade stops turning when in high grass #20
Heavy duty commercial has round holes. I kept sharp blades handy and changed 66 blades a week. Basically half the mowers every other day. Kept a few new blades to replace ones too worn. They'd wear in two on the back side where they turned up. I welded some of those back and used them again.
UNUSED PABREAK TCR380 - 84" HYD TRENCHER (A57193)
UNUSED PABREAK...
2012 BMW 328i Coupe (A55853)
2012 BMW 328i...
2007 POLARIS RANGER 500ETI RTV (A57192)
2007 POLARIS...
2009 Freightliner B2 School Bus (A55852)
2009 Freightliner...
2013 Dodge Durango (A53317)
2013 Dodge Durango...
20-Ton Hydraulic Bottle Jack (A55852)
20-Ton Hydraulic...
