ZD326 blade stops turning when in high grass
   / ZD326 blade stops turning when in high grass #1
tallyho8
Super Member
North of the Gulf of America, west of Westwego
Kubota L4400, Kubota ZD326
My ZD326 was laid up for a couple of weeks while I repaired the fuel gauge and with the hot weather and lots of rain we have been having my grass grew rapidly and was a lot higher and thicker than usual. I also have a mulcher on it which makes it even harder to cut tall grass. I bought 2 new cup washers for the blade and torqued it to 95# but one of the blades will slip and make a terrible racket when it gets in the tall grass. Anybody have a cure for this?
   / ZD326 blade stops turning when in high grass #2
what a dumb design, the blades aren't keyed?, I would torque the cup washer to blade at the proper torque, then I would weld the cup washer to the blade itself. Ridiculous design.
   / ZD326 blade stops turning when in high grass #3
This can happen when the washers or the cup covering the spindle are worn thinner from being loose and then the torque applied to the spindle bolt will not give the full pressure on the blade
I can understand not having the blade in a fixed position unable to slip, because if it was not able to slip if hit a chunk of concrete, it could bend the shaft or cause other major damage. It acts like a clutch on a pto but it should hold a lot tighter than it is doing. I did install new cupped washers. By my understanding, the cup covering the spindle is just a thin sheet metal dust cover and does not spin with the blade and the blade should mount tightly even if you leave the cup off. The bolt holds the cup washers tight against the shaft with the splined insert going through the blade and unto the splined shaft.
There is nothing stopping the washers from turning with the blade so welding the blade to the washers would not accomplish anything. Now welding the blade to the insert would lock it up and if you did not hit anything to bend the shaft would work except you would have to buy new inserts for the blades when you change blades which I do on a regular basis.
   / ZD326 blade stops turning when in high grass #5
Just for reference here is a picture of the setup tallyho8 is describing:
Is your lock washer #4 in good shape?
   / ZD326 blade stops turning when in high grass #6
If the blades have spline that fits on the spindle it sounds like the splines are worn or the blade was not installed properly on the splines. Slipping splines would make a lot of noise until the splines are ground away.
   / ZD326 blade stops turning when in high grass #7
Assuming the op has the bellview washers oriented correctly, I would be inclined to torque the bolts a little more. Perhaps add a 3rd washer and increase the bolt torque if there is enough thread (I've never added a 3rd washer).
I don't use a torque wrench on the blade bolts for my zd326 or zd1211, but I'm sure I keep them tighter than 98 ft/lbs.
I take the blades off to sharpen every 2 weeks or so, and have never had a problem with them.
   / ZD326 blade stops turning when in high grass #8
Try some new OEM blades and a new OEM belt on it. Check and adjust the belt tension.
I think the spec torque is 85ft.lbs. If you use an impact gun to tighten or you have over torqued you might have stripped some threads inside the spindle.
I'm suspicious you might have broken something on/in the spindle since you say you are hearing a racket when it slips. You might need to pull the spindle to see what's going on.
I wire brushed my blade down where the washers connect to it and I tightened the bolt to 110# and tried it out and it is working ok now. My old torque wrench might not be too accurate anymore. Time will tell if this works.
   / ZD326 blade stops turning when in high grass #10
Just the other day I removed my blades off my ZD1211 (I agree stupid overly complex design) to sharpen & balance. When I reinstalled them the right side blade screw would spin the shaft while trying to torque to 80 lbft & I’ve had them of many times with no issues. I removed it and checked assembly, it was proper & clean so I tried again to torque & once again it slipped so off with two blades to swap assembly’s with same results.
Had to touch it with the impact slightly before it would reach torque.
On my machine the cupped washers were assembled opposite from the drawing above.
When I removed them for the first time a couple years ago it was obvious due to witness marks how I received to machine so I reassembled the same way.
I just checked my shop manual & it is the same as thclimer.
Looks like I need to turn them around before damage is done.
Thanks for the post.
90cummins
2022 Toro Workman 07921 Electric Utility Cart (A51691)
2022 Toro Workman...
2022 Polaris Ranger 900XP 4x4 Utility Cart (A55853)
2022 Polaris...
CATERPILLAR 80" QUICK ATTACH BUCKET (A51406)
CATERPILLAR 80"...
2022 Polaris Ranger Utility Cart (A55787)
2022 Polaris...
2014 Jeep Cherokee Latitude SUV (A53424)
2014 Jeep Cherokee...
LaneShark LS3 (A56469)
