Zd21 starting issues
/ Zd21 starting issues #1
gevan57
Kabota ZD21
I have replaced the starter, solenoid and the ignition key switch. Now I知 finding a safety switch is faulty. How difficult is it to replace a steering arm switch?
/ Zd21 starting issues #2
I found a schematic years ago via someone on here outlining the ZD21. I had problems staying running, found a safety switch on one of the handles was out of adjustment. No part replacement was required. The switch is not real easy to get to, but it can be adjusted without removing any sheet metal.
Thanks for your reply. I did get it fixed and it was the safety switch as you mentioned.
2018 HINO 338 KNUCKLE BOOM TRUCK (A63276)
2018 HINO 338...
2014 KOMATSU PC170LC-10 EXCAVATOR (A65053)
2014 KOMATSU...
2002 Mitsubishi Lancer Sedan (A64557)
2002 Mitsubishi...
2012 Ford E-350 16ft. Box Truck (A64556)
2012 Ford E-350...
3268 (A63117)
3268 (A63117)
UNVERFERTH 6R36" RIPPER / STRIPPER (A64278)
UNVERFERTH 6R36"...
