Zd21 starting issues
   / Zd21 starting issues #1
gevan57
Kabota ZD21
I have replaced the starter, solenoid and the ignition key switch. Now I知 finding a safety switch is faulty. How difficult is it to replace a steering arm switch?
   / Zd21 starting issues #2
I found a schematic years ago via someone on here outlining the ZD21. I had problems staying running, found a safety switch on one of the handles was out of adjustment. No part replacement was required. The switch is not real easy to get to, but it can be adjusted without removing any sheet metal.
Thanks for your reply. I did get it fixed and it was the safety switch as you mentioned.
   / Zd21 starting issues #4
Glad to hear you got it going as leaf season is upon us!
2015 DODGE RAM...
New Holland TS6. 120 Tractor (A50322)
New Holland TS6...
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
2005 International 4200 Texoma UC-301 Pier Drilling Truck (A49461)
2005 International...
BUSH WACKER ST-180 ELITE BATWING ROTARY MOWER (A51406)
BUSH WACKER ST-180...
71063 (A49346)
71063 (A49346)
