ZD1211 and Coolant
   / ZD1211 and Coolant #1
Rob in Ontario
Kubota L4240
I didnt want to hijack the other thread on ZD1211s and Coolant.
My question is to add Coolant do I need to buy it from my Kubota dealer, or can I use green (or maybe it's yellow) coolant from my John Deere dealer that's much closer?
I think it's called Cool-Gard ll
I'm not losing coolant, just need to top up the overflow tank.
Is it okay to mix brands?
   / ZD1211 and Coolant #3
As an alternative adding little bit of distilled water would fine, as long as you don't dilute it too much for winter conditions.
   / ZD1211 and Coolant #4
My tractor manual specifies ethylene glycol based coolant. It does not specify a brand. A 50/50 blend with distilled water is basically the mix. Or you can buy it premixed by several brands at most auto parts stores.
Gehl RT210 Turbo Skid Steer Loader (A50514)
Gehl RT210 Turbo...
Land Honor 84" 3 pt Disk (A50514)
Land Honor 84" 3...
2020 KENWORTH T880 ROLL OFF (A51222)
2020 KENWORTH T880...
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A50459)
2007 FORD F-750XL...
Tires (A50322)
Tires (A50322)
2014 New Holland T8.360 MFWD Tractor (A52128)
2014 New Holland...
