ZD1211 and Coolant
   / ZD1211 and Coolant #1
Rob in Ontario
Kubota L4240
I didnt want to hijack the other thread on ZD1211s and Coolant.
My question is to add Coolant do I need to buy it from my Kubota dealer, or can I use green (or maybe it's yellow) coolant from my John Deere dealer that's much closer?
I think it's called Cool-Gard ll
I'm not losing coolant, just need to top up the overflow tank.
Is it okay to mix brands?
   / ZD1211 and Coolant #3
As an alternative adding little bit of distilled water would fine, as long as you don't dilute it too much for winter conditions.
   / ZD1211 and Coolant #4
My tractor manual specifies ethylene glycol based coolant. It does not specify a brand. A 50/50 blend with distilled water is basically the mix. Or you can buy it premixed by several brands at most auto parts stores.
72in Rock Bucket Skid Steer Attachment (A50322)
72in Rock Bucket...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2022 KUBOTA SVL75-2 SKID STEER (A51242)
2022 KUBOTA...
2011 Ford Utility Econoline Van (A50515)
2011 Ford Utility...
2025 Single Cylinder 40in Grapple Rake Mini Skid Steer Attachment (A50322)
2025 Single...
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
