ZD1011 Fuel Consumption and Compare to Z724KW
   / ZD1011 Fuel Consumption and Compare to Z724KW #11
Is there an option for a “Pro deck”?
if there is and you have lots of roots or rough ground, GET IT!
Yep the ZD comes with it. Kubota says it's supposed to provide 22% better fuel economy. Not sure if it really does. I will for certain be adding the lift kit for easy maintenance on the deck. That's seems like a good feature for $100+.
   / ZD1011 Fuel Consumption and Compare to Z724KW #13
I really like my zd1211 for a multitude of reasons, including fuel usage and handling. Diesel is just easier to deal with.
I don't know the fuel usage of the zd1021, but my machine uses a seasonal average of 0.83 gallons per hour, and in my use about 28 acres per tank (12.9g). That works out to about 2 acres per gallon, which would get you 12 acres mowed per tank assuming similar fuel usage.
   / ZD1011 Fuel Consumption and Compare to Z724KW #14
Do yourself a favor, I know it seems like I’m spending your money, but life is short, get the Z you really want and option it out the way you want to make your seat time a pleasure.
You won’t regret it.
Oh I definitely will. I did the same for my tractor and my sxs. When I make a purchase, it's usually for the long haul. I will definitely be getting a few extras such as the lift kit and chute lifter.
   / ZD1011 Fuel Consumption and Compare to Z724KW #16
I use a piece of plastic coated wire for a chute lifter. Wish I had the more professional version lol
   / ZD1011 Fuel Consumption and Compare to Z724KW #17
Easy to spend someone's money, but the commercial chute cover I use is worth every penny! Advanced Chute Systems, but they are a little pricey for what they are.
   / ZD1011 Fuel Consumption and Compare to Z724KW #18
It only hurts till the next bank statement cycle. Then it's all good.
I got them to "throw" in the lift. The chute I'm fairly certain I can build something. I think Ive made up my mind though.
   / ZD1011 Fuel Consumption and Compare to Z724KW #20
I have a Z724. Got the front lift and LEDs. It's a little thirsty being a gasser but I have no regrets. Would buy again.
2019 UTILITY 53X102 REEFER TRAILER (A52576)
2019 UTILITY...
16FT Flatbed Trailer (A51573)
16FT Flatbed...
JOHN DEERE 5125R LOT NUMBER 24 (A53084)
JOHN DEERE 5125R...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A53472)
80in HD Tooth...
1982 GOOSENECK 24FT TRAILER (A52472)
1982 GOOSENECK...
