ZD 323 tire pressure
   / ZD 323 tire pressure #1
MidTNDawg
Hilly terrain. Looking for suggestions for optimum pressure to achieve best traction and have sufficient inflation. Thanks for help. TractorByNet forums were a big, big help in my decision of what to buy last Fall. Doug
   / ZD 323 tire pressure #2
I'd let them down till you have full contact across the tire, with your weight on the seat that should be about right!
   / ZD 323 tire pressure #3
Back when I ran ZD's (ZD21 and the ZD326), I would run the front tires at max pressure. They seemed to pivot better. In the rears, I would run low pressure, if I remember right, around 10psi. I know they looked kind of like a radial tire looks like on a car. Like you should add some air to them. This seem to give me the best traction. Of course you could load the rear tires with fluid for max traction and a lower center of gravity on hills.
   / ZD 323 tire pressure #4
Are the tires big enough to hold enough fluid to make a difference?
Ken
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
2005 Ford F-250 4x4 Reading Crane Service Truck (A51692)
2005 Ford F-250...
2021 John Deere 310SL Backhoe (A53342)
2021 John Deere...
2011 IC Corporation PB105 School Bus (A52377)
2011 IC...
2022 John Deere 8RT 410 Tractor (A53342)
2022 John Deere...
Coleman Go Cart (A51573)
Coleman Go Cart...
