ZD 323 tire pressure
   / ZD 323 tire pressure #1
MidTNDawg
Hilly terrain. Looking for suggestions for optimum pressure to achieve best traction and have sufficient inflation. Thanks for help. TractorByNet forums were a big, big help in my decision of what to buy last Fall. Doug
   / ZD 323 tire pressure #2
I'd let them down till you have full contact across the tire, with your weight on the seat that should be about right!
   / ZD 323 tire pressure #3
Back when I ran ZD's (ZD21 and the ZD326), I would run the front tires at max pressure. They seemed to pivot better. In the rears, I would run low pressure, if I remember right, around 10psi. I know they looked kind of like a radial tire looks like on a car. Like you should add some air to them. This seem to give me the best traction. Of course you could load the rear tires with fluid for max traction and a lower center of gravity on hills.
   / ZD 323 tire pressure #4
Are the tires big enough to hold enough fluid to make a difference?
Ken
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
CATERPILLAR 259D3 SKID STEER (A50458)
CATERPILLAR 259D3...
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
JOHN DEERE 5125R LOT NUMBER 24 (A53084)
JOHN DEERE 5125R...
2013 Club Car Carryall 252 Electric Utility Cart (A51691)
2013 Club Car...
New/Unused 13ft x 20ft Single Garage Metal Shed (A51573)
New/Unused 13ft x...
