Z724 Hot Start
   / Z724 Hot Start #1
timswi
Elite Member
Beaver County Pa
Kubota BX23 TLB, Kubota RTV1100, Kubota Z724 & Polaris RZR 900 Trail
Have a Z724...Cold starts are very quick with no issues. Seems when I restart after mowing (5-15 min after) it sometimes has difficulty getting to WOT RPM. Never stalls but seems to struggle for 10 seconds or so. All new filters etc...Any ideas?
Also, since this was new it will puff what appears to be blue smoke when starting hot or cold. Doesn't use any oil at all. Koehler engine. Was told this is normal--Find that hard to believe.
   / Z724 Hot Start #2
It is a good idea to let it idle for a minute or two with no load before shutting down, that may help. As far as blue smoke, my 26HP Koehler power riding mower would smoke turning a corner. The way to eliminate that issue is to run the oil level no more than 3/4's of the way up between the add and full marks on the dipstick.
   / Z724 Hot Start #3
it's normal for a new engine to smoke a bit until the rings wear in!.. then it will stop smoking..
   / Z724 Hot Start
Well, it does have 100ish hours on it...Would have thunk they would be seated by now...Dunno, not hurting anything I guess.
   / Z724 Hot Start #5
I don't have a ZTR. I do have a mower with a twin cylinder Kohler. If I park it slightly nose down it will smoke when started, though it doesn't seem to use oil between changes. I've taken to parking slightly uphill (backing into its parking place) and the smoking has stopped.
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A51039)
2006 Magnolia Dry...
2015 CHEVROLET SILVERADO CREW CAB TRUCK (A51406)
2015 CHEVROLET...
12in Backhoe Bucket (A51039)
12in Backhoe...
2015 KENWORTH T370 QUINT AXLE DUMP TRUCK (A51222)
2015 KENWORTH T370...
2020 Peterbilt 389 Tri-Axle Sleeper Cab Truck Tractor (A49461)
2020 Peterbilt 389...
8 DRILL COLLAR (A50854)
8 DRILL COLLAR...
