Z665 JD Zero Trun
   / Z665 JD Zero Trun #1
PtownBubba
Prophetstown, Illinois
Z665
Just got my Z665, working fine,,,, reading up in the manual.
Transmission oil says it is 10W-30 , [not transmission oil] So, it takes regular 10w-30 motor oil ,, not transmission or hydraulic oil ?
Motor is a 27HP,,,, Briggs/Stratt [ Sure looks like one,,, no mfg reference ]
I am a fan of straight 30W oil for air cooled motors,,,,, any problems with using 30w oil instead of 10w30
   / Z665 JD Zero Trun #2
Double check with dealer. New model may get wrong info in the manual i guess. I don't see why you don't just use 10w30 in the engine though. Irrc my manual says no need to change the hydraulic oil, but mines is an older z465.
   / Z665 JD Zero Trun
1. Not changing oil,,,,,topping off fluid level,,,, 10w-30 motor oil for transmission just sounds weird.
2. Do not understand why multi-grade oil for a lawn mower motor,,, that never sees cold weather,,,, I have always used straight 30w in air cooled motors.
2018 John Deere 470G Hydraulic Excavator (A53421)
2018 John Deere...
Chery 7' 35 Drawer Workbench (A50120)
Chery 7' 35 Drawer...
UNUSED LANDHONOR LHR-RC920 CHAINS & BINDERS (A54757)
UNUSED LANDHONOR...
12ft Heavy Duty Aluminum Ramps (A55301)
12ft Heavy Duty...
UNUSED DIGGIT 6' HIGH FENCING - 1 ROLL (A54757)
UNUSED DIGGIT 6'...
