Z655 54" HC deck cleaning
   / Z655 54" HC deck cleaning #1
feetr2c
I'm in my second season with my Z and loving it. She is a BEAST! What are your suggestions for cleaning all the wet grass and clods of mud from the deck? I have used a garden hose and also have used shop air at 120 psi (works great if it's DRY grass). What I hate is all those little cupped depressions that are around each of the 3 spindles. Those get full of water and goo. Anybody ever filled them in with silicone or something to level out the surface for easier cleaning? I don't like to leave all the wet junk inside them because I'm afraid it will eventually rot them out. I'm tempted to drill holes in them so the water can drain.
   / Z655 54" HC deck cleaning #2
I don't wash under the deck.. just use the air hose (shop air). Mostly just mow grass when dew is off. But even if wet grass, I don't add anymore water to anything caked under the deck. Just makes a bigger mess and more "goo".
Occasionally, when changing or sharpening blades, I scrape out the depressions, but not very much collects there.
I don't think silicone or anything will stick in those depressions..
   / Z655 54" HC deck cleaning #3
I drive mine into the cornfield after it has been combined and mow a couple of 500' long rows. It cleans the bottom side pretty good.
New Mahindra 8100 CLGC Euro Loader (A50774)
New Mahindra 8100...
2015 Chevrolet Silverado 1500 Pickup Truck (A50323)
2015 Chevrolet...
2008 Freightliner B2 School Bus (A51692)
2008 Freightliner...
2015 Freightliner 122SD T/A Wet Kit Day Cab Truck Tractor (A50323)
2015 Freightliner...
2025 12V Diesel Pump, Nozzle and Hose with Meter (A50323)
2025 12V Diesel...
378748 (A51573)
378748 (A51573)
