Z4822 Battery Hooked up backwards
/ Z4822 Battery Hooked up backwards #1
robdog6942
My neighbor hooked up a new battery backwards for about 30 seconds, no smoke, no spark no nothing. He realized it and fixed it, but now it won't start (won't even crank over). The battery is still good, replaced the starter solenoid, verified the seat safety switch was still working, hour meter is on. Can anyone look at the wiring diagram for this model and tell me if I am missing something else?
/ Z4822 Battery Hooked up backwards #2
First things first... check all fuses and fusible links.. can't help with any diagrams.. but the basics will help. Main connections, fuses, relays, solenoids all need to be tested.. check for power and ground at starter, check for trigger signal at solenoid/starter.
Hopefully all he did was fry something cheap.
2027 . 500k BTU Wellhead Heater (A67714)
2027 . 500k BTU...
2007 WEEKEND WARRIOR BUMPER PULL (A67714)
2007 WEEKEND...
2025 48in Land Leveler Skid Steer Attachment (A66734)
2025 48in Land...
2015 PETERBILT 567 6X4 T/A DAY CAB TRUCK TRACTOR (A66091)
2015 PETERBILT 567...
2011 CARGO CRAFT PUMP CONTROL TRAILER (A67714)
2011 CARGO CRAFT...
330 GAL WATER TANK (A68842)
330 GAL WATER TANK...
