Mowing Z425 NOT CUTTING WELL
   / Z425 NOT CUTTING WELL #1
DANDERSON
LEES SUMMIT, MO
JOHN DEER Z425 48"
Hello all!! New to the forum. I just got a Z425 with a 48" cut. Started off good but now it is not cutting very well on one side. On flat ground if you look back you can see parts of the path still standing. I have the striping kit on it and when you back up it seems to cut just fine. Don't really want to mow my yard in reverse!!:confused2: Have the mulching kit on it right now. Also, when I turn to the left to turn around, it seems to cut much lower and leaves a circular path. A buddy told me to check the air pressure. Any help someone can give me would be great! Thanks.
   / Z425 NOT CUTTING WELL #2
Welcome to TBN!
I haven't owned a Kbota mower so I have no "inside" knowledge to give you. I'd start by just a good inspection. Is the deck level, look underneath (assuming you have a jack capable of lifting that bad boy) for obvious obstruction, check the tension on the deck belts, just make sure nothing is out of place first.
I'm sure a member with experience with Kubota mowers will chime in soon.
:welcome:
PH
Welcome to TBN!
:welcome:
PH
I thought Kubota's were orange? Mine is Green and Yellow!!!! :D
(4) Texas Built 25' Stand Alone Panels (A50515)
(4) Texas Built...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
2014 Caterpillar 257D Compact Track Loader Skid Steer (A50322)
2014 Caterpillar...
2013 KENWORTH T800 TRI AXLE CRANE TRUCK (A52472)
2013 KENWORTH T800...
Land Honor Skid Steer Utility Hitch Adapter (A50515)
Land Honor Skid...
2018 FORD F-450 XL FLATBED TRUCK (A51406)
2018 FORD F-450 XL...
