Mowing Z425 NOT CUTTING WELL
/ Z425 NOT CUTTING WELL #1
DANDERSON
LEES SUMMIT, MO
JOHN DEER Z425 48"
Hello all!! New to the forum. I just got a Z425 with a 48" cut. Started off good but now it is not cutting very well on one side. On flat ground if you look back you can see parts of the path still standing. I have the striping kit on it and when you back up it seems to cut just fine. Don't really want to mow my yard in reverse!!:confused2: Have the mulching kit on it right now. Also, when I turn to the left to turn around, it seems to cut much lower and leaves a circular path. A buddy told me to check the air pressure. Any help someone can give me would be great! Thanks.
/ Z425 NOT CUTTING WELL #2
Welcome to TBN!
I haven't owned a Kbota mower so I have no "inside" knowledge to give you. I'd start by just a good inspection. Is the deck level, look underneath (assuming you have a jack capable of lifting that bad boy) for obvious obstruction, check the tension on the deck belts, just make sure nothing is out of place first.
I'm sure a member with experience with Kubota mowers will chime in soon.
:welcome:
PH
Welcome to TBN!
:welcome:
PH
I thought Kubota's were orange? Mine is Green and Yellow!!!! :D
2017 Ford Fusion Hybrid Sedan (A61574)
2017 Ford Fusion...
*Selling at Royal Auction Tampa, FL Location* (A59228)
*Selling at Royal...
2000 CATERPILLAR 988F SERIES II WHEEL LOADER (A64279)
2000 CATERPILLAR...
2013 DODGE RAM 2500 CREW CAB TRUCK (A62130)
2013 DODGE RAM...
2020 Takeuchi TL8R2 Track Loader with 72in Tooth Bucket (A63689)
2020 Takeuchi...
14in Digging Tooth Bucket Excavator Attachment (A64194)
14in Digging Tooth...
