z225 cutting problems
   / z225 cutting problems #11
If everything is installed correctly the Trouble Shooting guide has this information: Uneven Clipping Distributation = 1) Cutting height set too low. 2) Mowing too fast. 3) Grass too wet.
Let me know what you find out. Maybe some others on this forum with a similar mower (Z225) will chime in with another solution. Good Luck
   / z225 cutting problems #12
Did you ever get this figured out? I'm having the same issue.
The spindle is not long enough to fit 4 blades on a Z225.
   / z225 cutting problems #13
Find something level to park the mower on, and measure the 4 blade tips to the surface.
Is the front of the deck lower than the back? Like 1/4 in to 1/2 in?
Mulching blades do not necessarily give the best cut.
The Gator blades I used do not give as good a cut as the regular blades.
It is also not a good idea to mulch tall grass, or wet grass.
   / z225 cutting problems #14
this is for rayikeo2 or anybody else who might know what can fix my problem.
just purchased z225 about year ago im having the same problem now with my z225. did you find out what was causing your problem
   / z225 cutting problems #15
   / z225 cutting problems #16
My deck was bent at the spindle which is why mine was uneven.
I installed a new deck but still do not think it cuts tall lawn (Bermuda) well in one pass.
   / z225 cutting problems #17
Thanks alot for your help that helps me getting started trying to find the problem i spoke to a guy today and he said it might be because my blade is bent on the right side. what ever it is hope its covered on warranty. Thanks again :)
New Kivel 4200 lb. Skidloader Forks (A50774)
New Kivel 4200 lb...
AGT Industrial Planter Attachment (A47384)
AGT Industrial...
2011 Chevrolet Cruze Sedan (A50324)
2011 Chevrolet...
1998 Kenworth Tandem Grain Truck (A50514)
1998 Kenworth...
2016 Chevrolet Caprice Sedan (A50324)
2016 Chevrolet...
2020 INTERNATIONAL LT625 DAY CAB (A51222)
2020 INTERNATIONAL...
