Z Force Lap Bar Steering Adjustment ?
   / Z Force Lap Bar Steering Adjustment ?
Thanks Bob
I just adjusted the left lap bar back to be even with the right bar and it drives pretty straight agan.
So what is the procedure to "equalize the drive on both sides" ?
I should not have to do that since it drives straight now though should I?
   / Z Force Lap Bar Steering Adjustment ? #12
I don't know the procedure but if it tracks straight ahead no further adjustment should be needed.
Bob B.
   / Z Force Lap Bar Steering Adjustment ? #13
Saxbird,
No, I never touched the control arm ferrules, as you called to them.
With the deck removed, lie under the Z Force and look up at the attachment rods that feed off of the lap bars. The threaded rods have a hime joint at each end, as well as a locking nut. Those are the rods I was referring to. You could certainly do the same thing with the control arm ferrules, but you might run out of threaded rod depending on how many turns you needed to add or subtract.
Gene
Mini-Excavator Quick Coupler (New/Unused) (A59225)
Mini-Excavator...
48ft all aluminum feather light wedge trailer (A56436)
48ft all aluminum...
LOT: (3) Water Meters, (2) Valves (A59076)
LOT: (3) Water...
flooring (A55758)
flooring (A55758)
20 LOWBOY BUMPER PULL TRAILER (A55745)
20 LOWBOY BUMPER...
IRanch Mini Excavator Auger (A57149)
IRanch Mini...
