Z-Force 50 Blade spindle greasing
   / Z-Force 50 Blade spindle greasing #11
I have a 2544 with about 10 hours on it. I just did the first oil and filter change and greased the spindles. You make greasing the spindles sound easy. What's your secret?
   / Z-Force 50 Blade spindle greasing #12
The Z-force 50 pulley covers didn't have access holes for the grease fittings so I modified them and my grease gun has a flexible hose instead of a rigid pipe. Also on this mower the outer spindles are clear of the frame. Your tractor from what I can tell from pictures on the Cub web site has the spindles under the footrests. But it looks like there are rubber access hole plugs.
   / Z-Force 50 Blade spindle greasing #15
Why couldn't they have put holes in the covers to allow access? My Wheel Horse does.
   / Z-Force 50 Blade spindle greasing #16
   / Z-Force 50 Blade spindle greasing #17
</font><font color="blue" class="small">( I have a 2544 with about 10 hours on it. I just did the first oil and filter change and greased the spindles. You make greasing the spindles sound easy. What's your secret? )</font>
How do you mean? I just lower the deck as far as it will go and grease away! I have been looking at a 90* adapter for the center spindle though as that one can be a little tricky.
I also found loosening the coupler on the grease gun a turn or so makes things MUCH easier (since you don't have such a hard time getting the damned thing off the zerk)!
   / Z-Force 50 Blade spindle greasing #18
   / Z-Force 50 Blade spindle greasing #19
A 90* adapter sounds like a great idea for greasing the center spindle.
By the way, I broke the plastic oil drain plug on my very first oil change. (Didn't turn it far enough or pulled too hard.) Rather than make a trip to the dealer I replaced it with a 3/8 pipe nipple, elbow, and plug. It works well. I probably won't bother to replace the broken plastic plug.
   / Z-Force 50 Blade spindle greasing #20
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A57192)
2008 INTERNATIONAL...
2001 Diamond 20' Fuel Trailer, VIN: 5FWFS18241R000024, Tandem Axle, Asset# 27 (A59076)
2001 Diamond 20'...
2016 CATERPILLAR 236D SKID STEER (A52709)
2016 CATERPILLAR...
2020 INTERNATIONAL MV607 REEFER BOX TRUCK (A55745)
2020 INTERNATIONAL...
2015 Ford Escape SUV (A56859)
2015 Ford Escape...
2012 DOOSAN G25 GENERATOR (A55745)
2012 DOOSAN G25...
