Yuchai dozer do I repair this or just leave it
   / Yuchai dozer do I repair this or just leave it #1
timbatrader
Pakihi New Zealand
YCT306S-S bulldozer Leyland 344 tractor, Mountain Raise MR926S wheel Loader, Hitachi 19U mini Excavator
Greasing my Yuchai YCT306S-S dozer the other day I noticed the rubber block on one side of the machine that the undercarriage frame sits on missing. So a new rubber block and buffer cap have been fitted. Also damaged are some lightweight ribbons of steel wielded over the slots in the undercarriage frame. I cannot see a purpose to these steel ribbons so why repair them?
When the rubber block is in place the frame cannot move far enough for the ribbons to do anything and if the rubber block disappears (I don't understand how but it happened to mine) the ribbon is nowhere strong enough to hold the frame and it snaps. Can anyone shed any light on their purpose?
The parts diagram shows the frame without the ribbons wielded on
   / Yuchai dozer do I repair this or just leave it #2
What year is the dozer?
I bought it "new" in 2012 but it had been on the dealer floor for a long time maybe three or four years
Here is photo of the other side the steel ribbon has been crushed when the blade frame comes down at the same time as the undercarriage come up on that side
   / Yuchai dozer do I repair this or just leave it #5
Okay, this is a later model. I can't see the "ribbon" you're referring to in that pic, but if it's what I think it is, it's supposed to keep the equalizer bar in (if it goes over the top of the retaining pin). Seems to me that there should be a retainer for the rubber cushion also. Yes, it is necessary, although it should not be contacting the wishbone.
   / Yuchai dozer do I repair this or just leave it #6
If the rubber cushion came out and the retaining strap was not in place the equalizer bar would come out and potentially cause a lot of damage to the swing frame pivot shaft and possibly break the transmission housing.
2014 Dodge Ram 5500 Chevron Wrecker Tow Truck (A51692)
2014 Dodge Ram...
2016 Ford F550 Altec Bucket Truck (A52377)
2016 Ford F550...
2015 JLG 449 12ft Drop Deck Equipment Trailer (A51694)
2015 JLG 449 12ft...
2016 JOHN DEERE R4038 LOT NUMBER 195 (A53084)
2016 JOHN DEERE...
2012 VANGUARD 53FT DRY VAN TRAILER (A52576)
2012 VANGUARD 53FT...
2019 Ford F-550 Service Truck, VIN # 1FDUF5HY1KEF71327 (A51572)
2019 Ford F-550...
