YT359C bottom plow?
   / YT359C bottom plow? #1
bigweights
john deere 4044m
Can a YT359c pull a bottom plow? What size? Do you think the IHMT can handle heavy tillage work without problems? I have 10 acres I plan to work up.
   / YT359C bottom plow? #2
I ran a two-bottom Ford Dearborn that I borrowed from a neighbor on my YT359C. I had no problems pulling this through the rocky clay that is common in our area. I did less than 10 acres, but I felt it went fast. The IHMT did not seem to bog down or struggle at all.
   / YT359C bottom plow? #3
Bigweights, How did this work out for you? I would expect you had no problems at all. This is where the IHMT should perform very well. The transmission should achieve hydro-lock(zero fluid pumping) somewhere in the middle of the gear range, the optimal point for minimizing energy loss and heat in the transmission.
2015 Ford Escape AWD SUV (A50324)
2015 Ford Escape...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2016 Ram 5500 4x4 Altec AT37G 37FT Bucket Truck (A50323)
2016 Ram 5500 4x4...
2019 Kenworth T880 T/A Wet Kit Day Cab Truck Tractor (A50323)
2019 Kenworth T880...
John Deere 7210 (A50120)
John Deere 7210...
2025 Swict 84in Bucket Skid Steer Attachment (A51691)
2025 Swict 84in...
