YT359 and Cat2?
/ YT359 and Cat2? #1
AuCivil
Alabama
JD4710
Anyone know why they don't use the Cat1/Cat2 combo 3-point arms like they use on the YM359 tractor? Seems like the YT359 could run some smaller Cat2 implements.
/ YT359 and Cat2? #3
OEM on the cab YT359C are CAT1. Spending a lot of time looking at implement weights and units that have both CAT 1 and 2 options on attachment pins. Still, making sure the swing arm adjustments are all the way pulled in and set with the drop pin holder on the left side and right side is the only catch. If you mess up and forget the arms will drag on the tread of the tire. Arggghhhh.
/ YT359 and Cat2? #4
New YT359A cab tractors have Cat I and II three-point hitches.
2022 EZ-GO ELITE...
2019 John Deere 1775NT Planter (A63111)
2019 John Deere...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
Wacker Neuson PT2 Water Pump (A59228)
Wacker Neuson PT2...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2024 Kubota M7-174D (Deluxe) 4WD Tractor - 244 Hours (A63688)
2024 Kubota...
