YQM-48 belly mower
   / YQM-48 belly mower #1
runningbird
Gisela, AZ
yanmar 1110d ,fx28d
does anyone know if the yqm-48 mower will work on a 135d? it is supposed to fit the 155 but I think the 135 is the same size.
thanks
   / YQM-48 belly mower #2
Went through my manuals. Only one I found with the YQM-48 mower has the YM165 and YM165D as the primary....inside the cover it says it will also fit a YM186 and YM186D, also a JD 650, Satoh Beaver III, etc.
Also says "and many other compact diesel tractors with 1 3/8" SAE 540 RPM PTO and Compact Diesel CAt 1 3-point hitch"
The other 2 manuals I have showing the 135 and 155 are for a YMM45 mower deck.
Hopefully some of the other yanmar guys will be of better help.
   / YQM-48 belly mower #3
It will fit the YM135. if it will fit between the wheels. The wheel base of the YM155 is 3" longer than the YM135. The tubes from the 3 point should have several holes to adjust to different tractors. You may be limited on how high it will lift, because it may hit the wheels.
2013 KENWORTH T800 DAY CAB (A53426)
2013 KENWORTH T800...
2020 Kinze 3505 High Speed 6/11 Planter (A53473)
2020 Kinze 3505...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A53426)
2019 INTERNATIONAL...
TRUCKING INFO (A50775)
Payment Terms (MUST READ) (A50775)
Payment Terms...
2013 Ford F-250 Pickup Truck (A51692)
2013 Ford F-250...
