Your towing rigs and trailers
   / Your towing rigs and trailers #3,941
And here's the sleeping quarters
   / Your towing rigs and trailers #3,942
2017 f-350 ultimate lariat 6.7, Load max 25ft trailer with John deere 110TLB.
   / Your towing rigs and trailers #3,945
Ive got a few f350's for real hauling, but here's my 1200 dollar "tool truck" with a free truck bed slide in the back hauling my 450 dollar trailer with some free truck toolboxes built into the side that double as shelves on the inside. needless to say, it was all rotted out junk when i got it and required a whole lot of fabricating and cosmetic work. The black truck bed liner on the bottom of the car and the diamond plate on the bottom of the trailer are covering what used to be a whole lot of weight reduction.
   / Your towing rigs and trailers #3,946
2020 Eagle 20' tilt 10k trailer towed with my 2004 Chevy Silverado 1500 W/T with factory tow package.
Looking at your picture, I see that you are hooking your chains to the "D" rings at the rear of the trailer. FWIW, if you use the seond stake pocket from the rear on eah side to use as tie down points, you will experience a lot less bounce of the tractor as you go down the road. Also, lower the flail to the deck when transproting. Less stress on the tractor.
   / Your towing rigs and trailers #3,947
Seeing how the rear chains have not been tightened, I would assume afterward he would lower the flail. Jon
   / Your towing rigs and trailers #3,948
My mini fleet, kinda a poor picture, can't see the trailers, PJ dump, Lamar dump, D/C flatbed and Load Max car hauler.
   / Your towing rigs and trailers #3,949
So is the old 1st gen semi-retired since you're sporting a new truck?
   / Your towing rigs and trailers #3,950
Here is my 2610 on my sure-trac 18+2
2015 International Durastar 4300 SBA 4 x 2 Water Truck, VIN: 3HAMMMMN4FL510006, Cummins Turbo Die... (A59076)
2015 International...
2021 Husqvarna YTH18542 42in Riding Mower (A56859)
2021 Husqvarna...
2025 JMR 40in Single Cylinder Brush Grapple Mini Skid Steer Attachment (A56857)
2025 JMR 40in...
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A55973)
2014 MultiQuip...
2015 Goose Neck Cattle Trailer (A53317)
2015 Goose Neck...
2023 Kubota KX057-5 Compact Excavator with Angle Blade (A56435)
2023 Kubota...
