Your towing rigs and trailers
   / Your towing rigs and trailers #2,831
That would require knowing what the whole load weighs making your hitch scale nearly useless. It's not that big of a deal anyway.
Which is why I have a separate tongue scale that I can put on a floor jack and weigh the front of the tractor, then weigh the back of the tractor. Jon
   / Your towing rigs and trailers #2,832
The weight distribution changes when you set the implements on the ground.
   / Your towing rigs and trailers #2,833
   / Your towing rigs and trailers #2,834
The fact that the rear tires of the tractor are over the axle, putting the "heavy end" toward the tongue. And affirmed by the poster as perhaps 25%. I'm a bit too OCD to guess, so when I get my new trailer I'm gonna get one of the hitches with a scale.
I assume you do know that you can calculate the trailer lbs. on the hitch using a bathroom scale.
If you tow every week, the bathroom scale method would be a PITA, but for occasional use, it works just fine.
I get the loaded trailer weight at a municipal scale.
I try to set up my load for 10% - 12% on the hitch.
I also do have air bags.
   / Your towing rigs and trailers #2,835
My assumption is, this only works with bumper pull trailers. I don't know of a single bathroom scale that could handle any of my goosenecks even when empty.
   / Your towing rigs and trailers #2,836
I've never seen a bathroom scale that reads over 300 pounds. Even with a lever arrangement that's unpractical.
   / Your towing rigs and trailers #2,837
Y'all just fell into his rhetorical trap! :laughing:
   / Your towing rigs and trailers #2,838
I go by look and by feel. Guess I'm a weirdo. I'd be too my destination before a scale. I'm fine with all the tongue weight the truck can handle.
   / Your towing rigs and trailers #2,839
Where I come from, that's called experience...........:drink:
Been towing for about 50 years, I'm pretty confident about how I load and secure. I know that look and feel.
   / Your towing rigs and trailers #2,840
Same here, I look for the tongue to drop 3-4" and call it good.
Aaron Z
LOT: (6) Pneumatic Tools, (3) Impact Wrenches, (2) Cut-Off Tools, (1) Grease Gun (A59076)
LOT: (6) Pneumatic...
SCALES & PEA (A58374)
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A56436)
2023 Unverferth...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
2012 KINZE FLAT FOLD ROW MARKERS SET FOR 12 ROW 36/38 STACK FOLD TOOL BAR (A55315)
2012 KINZE FLAT...
2018 Elgin Broom Badger Sweeper, Kubota Turbo Diesel Engine, High Dump, Dual Tilted Gutter Brooms... (A59076)
2018 Elgin Broom...
