Your towing rigs and trailers
   / Your towing rigs and trailers #2,471
You can get the 8' bed on 3/4 ton and up crew cab Rams.
I didn't mean that you couldn't get the 8 foot bed, just that you weren't limited by only 5.5 and 6.5 foot boxes. Sorry if I wasn't clear on that.
   / Your towing rigs and trailers #2,472
I'd say not really on the 6.7L, in the context of 6.0L type problems.
Plan on using a 2 post lift, for any significant under-hood work, as the cab will typically need to be lifted.
Sno touched on it, but it bears repeating - coolant quality is critical, esp. with an EGR system in place. I wouldn't run any modern diesel w/o a good quality fuel additive - Stanadyne is my preference, but there are other good options (ex. Optilube XPD) discussed in various threads on here. One of the reasons I use Stanadyne is how it handles water - it coalesces small water drops (I think the term Stanadyne uses is de-emulsify) into larger ones, so a stock filter will perform better at separating water.
Most modern diesels are very sensitive to fuel filter maintenance. Diaphragm pumps really don't like input restriction, so whereas a 7.3 will often run with a filter very past it's Change By date, on a newer diesel that can mean changing a pump. Do not exceed Ford's service interval on fuel filters. Some guys confuse upgrading a filter (lower micron) with being able to drive 200k on one fuel filter.
The 6.7 is a blast to drive, and is very capable. If your brother is as maintenance-attentive as you are ur, he should be fine. Where some guys got into trouble with newer diesels was thinking that they were as low-maintenance as the olde iron. We are definitely into Dating a Supermodel territory today.
Rgds, D.
Appreciate the detailed response.
His vehicles tend to last a long time... and one of the reasons he bought local is so the selling Dealer would also be servicing... also bought the Max Ford extended warranty.
This is the first Diesel Truck in the family... so nothing really to compare.
Would it be safe to say the Factory Service interval is OK on a 2016?
The reality is 90% of the time it will be used as a car... 10% of the time will be towing the stock and dump trailers...
   / Your towing rigs and trailers #2,473
I guess what I was asking is "how can it add 80hp and IMPROVE economy over stock?" Seems too good to be true. If true, I want in! Lol.
It's a payoff... so much more peppy, I can't keep my foot out of it, it's d@mn quick for a 10k lbs truck. If I can stay out of it, I gain 2mpg. (Proven by hand calculated simular situation highway driving) 65mph interstate I can get 14mpg. Up it to 75mph, it drops to 12mpg.
It gets better economy by changing injector timing and trans shifting/torque converter lockup, among other things.
   / Your towing rigs and trailers #2,474
This has not been my general observation. It's more work to try and play "gotacha" on a technicality than just doing the repair. Maybe it's just a Wyoming thing, but Ford doesn't bat an eye with a deleted truck here. They even know emissions equipment cause more harm and grief than their worth.
Not my experience with ford at all. Always had the hardest time getting ford to honor anything.
   / Your towing rigs and trailers #2,475
I don't know any dealership like that. When the turbo went on my still warrantied Subaru, the service manager was adamant that they had to examine the oil to see how black it was before they would agree to replace it under warranty. According to him, if you don't change your oil frequently enough it can cause the turbo to fail! I guess he was satisfied with the colour of my oil because he replaced the turbo, but I was left with the distinct feeling that this guys was a real stickler for the rules and wouldn't let very much slide.
   / Your towing rigs and trailers #2,476
I've heard a lot of Automotive cases over the years... Ford was NOT part of the program so no experience from the bench on Ford as it were.
All of the other manufacturers would point out Modifications and it was the Arbitrators decision as to cause and effect if any.
It's no different than establishing required maintenance based on the operating conditions...
And it would get sticky at times when there were gaps or scant Dealer service records... just one more thing into the mix to consider.
From experience with friends I do know the local Ford Dealer would refuse to process suspension claims of trucks that were lifted, lowered or ran tires/rims outside OEM spec. and for the most part the decision stood.
   / Your towing rigs and trailers #2,477
We have more trucks on the road here in Wyoming by probably a 2:1 margin. The dodge dealership here started denying warranty work for engine modifications, just emissions stuff, and people and business moved to Chevy and Ford. It did not go unnoticed by Ford and Chevy. Guess who now looks the other way...
I have literally seen a diesel tech go take a picture of a stock truck's engine if Ford Corporate wants pictures of the engine bay. I have a coolant filter on a 6.0 and the head diesel guy had to take some pictures of the engine to support replacing the turbo boots. It wasn't my engine they sent to Ford. They know the game and what puts food on their table.
It probably helps that Wyoming hates the feds telling us what we can and can't do.
   / Your towing rigs and trailers #2,478
Maybe it's just me but I don't want to pay 50 or 60k for a truck and then start having to spend a bunch more money to ( bullet proof ) a truck to do the work that I need it to do, for what they price these new trucks at I would expect mine to be somewhat ( bullet proofed ) when I purchased it.
   / Your towing rigs and trailers #2,479
Lots of the MSRP on trucks in stock in North of 70k... as mentioned... about the same price of my first 3 homes combined and I live in the SF Bay Area!
I never have been a fan of extended Factory Warranties... today... they have more than paid for themselves on Domestics and European makes.
   / Your towing rigs and trailers #2,480
BulletProof is a term used in regards to the International-Navistar 6.0L & 6.4L PowerStroke Diesels from 2003-2010... there were common issues that came up both from emissions devices and factory design issues. They are so widely known that there is a complete market industry based on fixing those issues.
Deleting emissions junk is common across all brands, including the new in-house Ford diesels. Sooooo, the term BulletProof is not a loose term used when buying and modifying today's modern diesel engines... you won't have to BulletProof the new ones.
2018 WACKER NEUSON RTSC3 ROLLER (A52576)
2018 WACKER NEUSON...
2012 Ford F-150 Crew Cab Pickup Truck (A53422)
2012 Ford F-150...
2012 Chevrolet Impala Sedan (A54815)
2012 Chevrolet...
2005 Chevrolet Colorado 4x4 Pickup Truck (A55852)
2005 Chevrolet...
2008 Geringhoff NS800 8R30 Corn Head (A53485)
2008 Geringhoff...
