Your most used/valuable attachment?
   / Your most used/valuable attachment? #51
Brandi - that is pretty cool. Good for you. That is some kind of an attachment. What I meant was, when finish grading, I wondered how you "floated" your backhoe. Seems the 46 Backhoe on the back of my John Deere doesn't necessarily have a "float" position on it although I have to admit, I've never tried "float" anything with it. I'm wondering how you finish grade with it other than just to lower it to a certain depth and start pulling forward.
At any rate, that is quite the attachment. Quite impressive! Thanks for posting.
Oh.............how do you float it:confused2:. You have to be able to dance, chew gum, and rub your belly at the same time.:laughing: Actually, its just hours and hours of running the backhoe:D. Kinda comes easy now.:licking: I am planning a front grader blade off of the loader next.:cool: It will have a remote diverter to change from tilt to grade angles left and right. So you have to get off:ashamed: to change from left and right angles to left or right tilt. Then it will run off of the diverter valve button on the joystick. I would love to get a surplus propane tank to make the blade for that project. But folks want to many $$$ for them. Thanks for liking it.
hugs, Brandi
Well, that rules me out. Can't do more then one thing at a time. Again, congrats on a terrific invention/attachment and best wishes in your next endeavor - looking forward to the picts of that one to!
   / Your most used/valuable attachment? #53
Us mechanics call that a bullet. I haven't taken the time to make 1 & 1/2 inch and 2 inch bullets yet. The same diameter will work also. hugs, Brandi
You just need the main pin "bullet". Use that to install the main pin and the just operate the BH to lift the bucket. It swings easily then and is easily lined up for the second pin.
   / Your most used/valuable attachment? #54
I know...........I do it a lot when I put the auger on there. It's just awkward moving the thumb around under the dipper stick. My thumb is 1 inch steel. Kinda heavy. The bucket pins are 1 & 1/2 inches. Two inch bullets would be for rebuilding the cylinders.
hugs, Brandi
   / Your most used/valuable attachment? #55
Maybe if you led with your left foot?:laughing:
hugs, Brandi
   / Your most used/valuable attachment? #56
Depends on the season, but the RFM and snow blower are definitely the most used. Unless there is a specific task, the mower stays on all Spring, Summer and into Fall...the blower stays on the Winter (which, here in Vermont, is pretty lengthy).
   / Your most used/valuable attachment? #57
My most used attachment would be the 6' Loflin Monster Grapple. Loflin Fabrication
A dead leaner in the woods
Put a chain around the bottom.
And backed out.
Added it to the others that I drug out.
Off to the burn pile.
Wow Faxman.... That is quite the attachment. Great picts. Very cool.
2019 Freightliner M2 106 AWD Terex Hi-Ranger TC55 55ft. Insulated Material Handling Bucket Truck (A55973)
2019 Freightliner...
New/Unused CFG Industrial QH12R Mini Excavator (A57453)
New/Unused CFG...
2000 Nabors 46ft. 40 Ton T/A Flatbed Equipment Trailer (A55973)
2000 Nabors 46ft...
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
2018 Ford F-550 Altec AT48S 47ft Bucket Truck (A55973)
2018 Ford F-550...
2012 Big Tex 14ET-20BK 20ft T/A Flatbed Trailer (A55851)
2012 Big Tex...
