IIRC, that was the re-build from that crazy high-hour EPA site project. Amazing what hours these things will sustain.Several years ago I acquired an EU2000i because it was burning a lot of oil.
I bought the repair manual & disassembled it to determine cause.
No obvious problem found so I replaced the rings & I wasn’t quite happy with how it idled after the repair. In the process of removing the tamper resistant cap on low speed adjustment I broke the screw & had to order a replacement. After installing the screw I started it up adjusted the idle mixture then put a progressive load on it starting at 500 watts then 1000 then 1500 watts.
I ran a tank of fuel thru it during test/breakin and it now runs like a Honda
Awesome machines!!
Anyone who worries about heat & lights should have one.
90cummins
I watched another of Condon's vids, rebuilding an EU2000i. Didn't realize the head/block was one piece. It's just more time, for someone with his/your skills, but the crank and piston had to be pulled to change a valve. What did surprise me a bit, was the amount of cracking on the timing-belt. That EU had hours on it, but wasn't much more than 6 years from production, based on the emission-sticker.
If you have an old EU around, it might be time to get a "spare" one, in case the timing-belt let's go.... not picking on Honda (seriously), as any timing-belt design has this vulnerability, vs. push-rods.
More so, that ^ is a point to keep in your back-pocket, if you need extra justification for the household CFO, to speed dualing-up generators
I do like Hondas. They have been the portable gen of choice for severe middle-of-nowhere operation, for a very long time.
Rgds, D.
