Your last generator Maintenance Run
   / Your last generator Maintenance Run #6,314
Is the bathroom heater a PTC unit? If it is then it could be drawing more than rated on startup in the cold.
I'd also check your battery connections and health, unexpected voltage drop can lead to inverters sucking scary input currents for a time.
   / Your last generator Maintenance Run #6,315
Not familiar with PTC heaters.
Heater is typical resistance heater coil. That’s a good point need to check batteries & gen to battery connections.
Son bought a house with many issues needing attention such as soft roof areas needing temporary sealing & hundreds of huge logs that needed to be relocated from front yard driveway before snow.
This weekend may be mine to troubleshoot the system.
Time to get throw some wood in the furnace 19 degrees out side.
90cummins
   / Your last generator Maintenance Run #6,317
Interesting units.
Always learning something here.
90cummins
   / Your last generator Maintenance Run #6,318
I learn a lot from folks a lot more experienced than I am.
besides I screw up a lot...;)
one of the oldest participants in the Good Morning thread (Sodamo) is fully off grid on top of the Big Island in Hawaii and has a sophisticated power generation system. Including one or two generators for backup.
Lot of high tech equipment he has to service regularly. The discussion is often over my head, as it is here, but that's how you learn.
I'm on my second year of a 100% synthetic oil change on my Westinghouse 9500 gen, with about 15 hours on it. It still looks like new and right up to the top. Never run on gasoline, always propane.
do I really need to change this oil every year? No filter, so that's a plus for more regular changes. Oil is so good now, and if it doesn't get dirty, do we need to throw it away so often?
I'm in PA so full seasons, condensation, etc.
I run all my equipment every several months, particularly the snowblower. EFI, starts right up. Power is lost regularly thanks to trees coming down that I don't need to exercise gen. It gets its own exercise, usually for 2-4 hours at a time.
I know it would have added another hundred bucks to the price, but sure wish this motor had pressure lube and a filter.
   / Your last generator Maintenance Run #6,319
Running on propane your small engine hasn't gotten any combustion contaminates in it to change the color. With no filter to catch any debris or wear particles they are being circulated, I would change the oil just to remove any wear metals present. The oil itself is likely to be in fine shape except for wear metals. It doesn't hold much so it's not a large financial issue to change it.
Propane and natgas are great fuels, for the reason Lou cites.
Not re. oil quantities.... even today, small engines don't cost much to delta the oil.... but this discussion reminds me of researching a Champion generator a year or so back..... Amazon reviewer even listed the PN, for an aftermarket dipstick he bought - correct length obviously needed, but importantly, magnetic.
Simple Things, That Work.... (realizing.... a lot of the small stuff is not cast-iron lined).
Rgds, D.
204158 (A57193)
204158 (A57193)
Truck Metal Cargo Storage Box (A55788)
Truck Metal Cargo...
2019 Chevrolet Tahoe (A56859)
2019 Chevrolet...
2015 CHEVROLET SILVERADO 2500 (INOPERABLE) (A58214)
2015 CHEVROLET...
Kubota SVL95-2 High Flow Cab Skid Steer (A55302)
Kubota SVL95-2...
Ford F450 Bucket Truck with Altec AT200A Boom (A56435)
Ford F450 Bucket...
