Your last generator Maintenance Run
   / Your last generator Maintenance Run #5,801
I had a little fun with this researching, yes it gets very complicated and expensive too. IM and RFI can be controlled but not an originally square or notchy sine wave that's supposed to
be smooth. In other words, hard to put humpty dumpty back together again. Unless you basically start "all over" and that's the complicated part. Over my pay grade...
none of the ads on the Westinghouse gen a few of us have lists any thd spec. Had to go to company site, not very encouraging:
Total Harmonic Distortion ≤23%
hopefully that is worst case. How expensive is a THD meter/harmonic analyzer?
I have used a work truck inverter since 1990 back when they cost a lot...
The power produced was fine for power tools but my Makita charger refused to work as did some other electronics.
   / Your last generator Maintenance Run #5,802
No enclosure its a 9.1 hp diesel
and its very quiet you can stand
right next to and talk to anyone
don't have to raise your voice
3.4 gal tank will run at half cap
for 23 hours or full for 6 hours
Just turn the key and starts
real happy with it. will be using
it to run my air compressor to
put up a fence wood fence using
a staple gun Its a 2021 year
willy
Yanmar must have been busy working on noise emissions.
Is yours an L100??
90cummins
   / Your last generator Maintenance Run #5,803
Our Yanmar Diesel 5500 watt gen
takes 3.4 gal diesel will run for 23
hours on half tank and you have to
be about 5 ft to it to know that its
running
willy
Never found that one before when looking. Looks interesting. They don’t list THD.
   / Your last generator Maintenance Run #5,804
So I had an engineering hunch that a "Constant Voltage Transformer" would be the miracle fix in the case of small to medium scale generator power (Last time I covered them was in 2005, I feel old) and yes a CVT will eat a square wave supply and give you a sine wave output: What is a Constant Voltage Transformer - an introduction to the perfect sine wave If it works with a square wave, it will work with any generator that outputs any amount of THD. Not super efficient but perfect for intermittently powering critical loads.
   / Your last generator Maintenance Run #5,806
90cummins Our model is YDG5500W-6El
I think that I paid aproxx $3500 I ordered it
from K&S Tractors Lubbock, TX early last year
willy
willy
Thanks for the 411 Willy..... small(ish) modern diesel gens are not that easy to find.
Being Yanmar, I'd expect it is well designed for this, but need to ask...... how easily does it pull-start ?
Looks like it has a healthy 12vdc output built-in (y)
Rgds, D.
   / Your last generator Maintenance Run #5,808
I'm lazy I just turn the key I'm
old and kranky 82
It really don't seem to be that hard
to pull to start it has a lever you push
before you try to start
willy
   / Your last generator Maintenance Run #5,809
This discussion makes me miss my old job at the technical college: I had seven figures worth of electrical engineering lab and test equipment at my disposal... I could have setup some really cool demonstrations in response to the questions being asked here.
old and kranky 82
willy
With that Decompression lever, should be not too bad....
Rgds, D.
2430 (A51248)
2430 (A51248)
2005 Ford F-150 Pickup Truck (A54814)
2005 Ford F-150...
Hercules Safe (A53316)
1988 John Deere 4250 (A53314)
1988 John Deere...
Decorative Pig Statue (A55758)
Decorative Pig...
2014 Chevrolet Cruze Sedan (A53424)
2014 Chevrolet...
