Your last generator Maintenance Run
   / Your last generator Maintenance Run #5,351
Id much rather have our snow than ice. Been there done that.
   / Your last generator Maintenance Run #5,352
Those pictures were (today) before lunch. This is now.
Crazy stuff.
I guess I'll unplug the block heater now. 😆
   / Your last generator Maintenance Run #5,354
In the last 2 weeks we had 2 days of
29 & 31 degrees for low and 50's high
but mostly 40's night and 70's day. No
power outages so far so no need to run
generator. Suppose to run for 23 hours
on 13 liters of diesel at half load haven't
tried it out to see if its true. electric start
and chose it over gas diesel lasts a long
time and reading about the gas generators
having too many problems. Never had
any problems with the gas until the gov
step in with the corn juice and just like
the a/c freon 12 works great never was
bad for the environment but they had
an instant replacement so you know
something fishy about that deal. 134A
replaced the 12 now they are changing
again so the cost to us is going to be
higher as the Repair shops had to spend
$5k to $20k for new equipment to work
on the 134A. gov steps in walla a crap
shot
willy
How many continuous kw rated is your generator Williy ?
Rgds, D.
   / Your last generator Maintenance Run #5,358
Mine automatically exercises' itself for 15 minutes weekly It's a John Deere diesel 30 KW Generac plumbed into my 500 gallon diesel storage tank. Runs the entire farm. 30 seconds after utility drop out, it assumes the load. 15 seconds after the utility comes back online, it kicks out and 'cools down' for 30 seconds. 100% turnkey.
   / Your last generator Maintenance Run #5,359
I’ve got mine set up so that it has to see 5 minutes of utility on frequency and voltage within 7% of nominal leg to leg and each leg to neutral before it will retransfer. 15 seconds seems awfully short for the number of times we get the utility to come back and then go off again shortly.
2004 CATERPILLAR 420D BACKHOE (A51406)
2004 CATERPILLAR...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A52706)
2018 GENIE GTH-636...
2017 FORD F550 XL SUPER DUTY BUCKET TRUCK (A51406)
2017 FORD F550 XL...
2012 PETERBILT 388 DAYCAB (A53843)
2012 PETERBILT 388...
2018 Doosan DL220-5 Articulated Wheel Loader (A53421)
2018 Doosan...
NEW HOLLAND TC30 TRACTOR (A51406)
NEW HOLLAND TC30...
