Your last generator Maintenance Run
   / Your last generator Maintenance Run #3,621
when i built my basement in the last century (1996), i coated the concrete with 2 layers of a product called thouroughseal...i think thats what its called. a grey coat then a white coat to make sure i had 2 coats. then a 1/4" layer of Bituthene over a primer. thats a self sealing product. then installed a layer of 1-1/2" insulation board to protect membrane. I have never had any leaks.
also installed a perc pipe system.
   / Your last generator Maintenance Run #3,622
PASSED INSPECTION TODAY and the system works, inspectors said it was best built home system they seen. I got a Deep Sea 7320 controller to run a dumb Generac auto transfer switch. 36KVA turbo charged 4 cyl perkins engine 1850 rpm diesel, hooked to 4 wire dedicated single phase 36kva MeccAlte Alternator with Digital voltage regulation, in a Aluminium level 2 sound enclosure, on board battery maintainer and alternator chargers. Based is rated at 160 MPH wind using two concrete railroad ties $30 each. See pic of Switch
   / Your last generator Maintenance Run #3,623
Nice job, but what prey-tell are you going to run with that?
I had my 7.5KW Onan/Cummins Quiet Diesel going yesterday during an outage, powering seven buildings, heat shut off (Fires Going) and drawing under a thousand watts. Was worried about wet stacking! lol
   / Your last generator Maintenance Run #3,624
If your world is all wonderful and everything works as normal during an outage, of what use is that if you have to start farting around at an unprepared neighbors? Just sayin. Neighbors with sump pump issues, frozen water lines and so forth. I thought the purpose of having a good generating system was to take a HOT shower, relax and watch a movie while the mayhem unfolds in the world outside. lol
The realities of living in the big city...
At work we use a number of UPS for critical equipment... only need to work for 10 seconds max which is the time it takes for the genset to take over...
It sure has saved a lot of time with the PBX, Computers, etc...
   / Your last generator Maintenance Run #3,625
Yeah. My computers are on a UPS, which sure saves a lot of aggravation starting them up again. Now, if only I could tell the microwave that no one cares about the time and date.
   / Your last generator Maintenance Run #3,626
The guy wanted no load shedding, I want everything to run just like on street power. Also has 5 ton AC, pool, etc. On first run he was drawing 15Kva. Barn, freezers. Right now it waits 3 minutes before it declares power down, one or two minute warming depending on coolant temp. Upon power return it waits 4 minutes, then cut back street power and 2 minute cool down. Monitors and logs street and gen power. The whole system was less than a 22Kva Generac install. This will run 30Kva continuous, 36Kva for about 15/20 minutes. It will handle lock rotors at 170% for 15 seconds.
   / Your last generator Maintenance Run #3,627
I guess there are two trains of thought. One, business as usual, fuel isn't an issue and two, conservative emergency system, conserving fuel. The PROBLEM as yesterday is ALWAYS not knowing how long an outage will last.
   / Your last generator Maintenance Run #3,628
Why can稚 microwaves have battery backup.....what would that add to the cost...$ 0.50
   / Your last generator Maintenance Run #3,629
Yeah, why? Or just a setting to eliminate the clock and all those functions associated with it. Believe it or not, mine has a voice recorder. Don't know how I ever made it this far without that feature. Makes me wonder now if any VCR ever had battery backup?
   / Your last generator Maintenance Run #3,630
We hope it will do both, for small storm damage 2 hours to 2 days it will run on the on board tank, hurricane go fill 4 to 6 55gallon drums with off road diesel, park trailer full of drums next to it, start turning things off. That Perkins engine will sip fuel when not loaded.
2016 Peterbilt 567 Tri-Axle Dump Truck (A51692)
2016 Peterbilt 567...
2017 COTTRELL TRAILER (A55788)
2017 COTTRELL...
2010 FREIGHTLINER CASCADIA TANDEM AXLE MID ROOF SLEEPER (A56138)
2010 FREIGHTLINER...
2008 BMW 535xi AWD Sedan (A53424)
2008 BMW 535xi AWD...
YANMAR Vi025-6A EXCAVATOR (A52706)
YANMAR Vi025-6A...
