Your last generator Maintenance Run
   / Your last generator Maintenance Run #2,921
Info for Florida or other storm prone areas. Turned in the permit for a ATS generator hookup and they wouldn't issue it without certified storm rated base. Which means you have to a have state certified engineer run the wind calculation for your unit and base at your wind zone. See the attached pdf. So if building your own configuration of genset and homemade base you will to hire an engineer
  • Tradewinds-GREE-VIREO_ConcPadMount_4-01-19-DigID.pdf
serviced the little Champion 3100 inverter gen.
First I dug out the mud wasp work, for the third time, even under the factory cover.
Had run carb dry last time. Not doing that again...
Pulled ten times. Nothing. Pulled another five. Nothing. Sprayed a small amount of starter fluid in the intake area, before the filter,
and it started right up and ran perfectly. Ran a 1500 watt heater on it for about fifteen minutes, then changed oil.
Stuck on new label saying 10/30 Syn Aug 2019
Next time I'll change the plug, or rather inspect it and I'm sure it will be pretty clean.
We throw away so many spark plugs today for no reason, not like the old days
where your big buy from JC Whitney was a spark plug cleaner.
Nicely done d. I prefer wet storage, full tank, properly stabilized Efree fuel....... but, there are plenty of examples on here of guys who are successful with many different approaches.
I scooped up some of the fine-wire (EZ start) versions of the RJ19LM while they were still available, that's what I'll be using next change. Though, short of the China Specials plugs that come in offbrand gens, most any name brand plug today will give good service in most of our applications.
I still have my spark plug cleaner, that I haven't used in "a while". I know if I throw it out, within the next month, I will be diagnosing something that has a rare plug, that can only be ordered online, with a multi-week delivery...... me an 'ol Murph go back a ways.....
Between mice and mudwasps, it almost seems worth designing an equipment storage enclosure sealed with window screening.,...
Rgds, D.
Not living in a hurricane or tornado zone (on your scale), that's something I hadn't considered. Good info.
I expect they are chasing the Engineer's signature.... the old Transfer Liability Game..... but I'm wondering if you can elect to just use the Worst Case requirement, and pour for that ?
Rgds, D.
   / Your last generator Maintenance Run #2,924
We asked can't we just pour a 4 inch pad, and answer was no wind report no permit.
Hard to see how that would be more of a potential threat, than what many people have randomly stored on their property w/o any permit needed.
The building officials who are regulating this have no idea what Wind Zone you are in ?
I Know Nothing - YouTube
Rgds, D.
   / Your last generator Maintenance Run #2,926
Each county gets to decide the year of the standards book they will work from, and the wind codes were just updated. Miami was upgraded to 185mph from 150mph, same with which year of NEC code book. The wind formula was tweaked also. Too many road signs and traffic lights blew down. The rules are not retroactive and point is to make the new stuff better
   / Your last generator Maintenance Run #2,927
My gen is a little big/awkward for me to get in an enclosed bag, so figured I'd cure mud wasp problem (3rd time...) by using duct tape
for yet another task. But...leaves a residue after a while, so I wondered, what tape do I have that will leave the least glue residue on the unit?
The shiny hvac tape? Six inches of tape and it's all covered.
perhaps there is a better idea...though the bag will absolutely work.
Maybe I could roll it back into a 33 gallon bag.
Have a bunch of physical issues so horsing this thing around or picking it up is off the table.
   / Your last generator Maintenance Run #2,928
never heard of this "option". Does finer wire wear out faster?
sounds like a good cold weather plug.
   / Your last generator Maintenance Run #2,929
Try some wide electrical tape. Especially covering up the plugs.
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A52706)
2020 CHEVROLET...
air compressor (A55758)
air compressor...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A55315)
2003 International...
2012 MACK CXU613 DAYCAB (A55745)
2012 MACK CXU613...
Mohawk 12,000lb Two-Post Electric Auto Lift (A54811)
Mohawk 12,000lb...
